09-15-2010, 04:56 PM | #1 |
Quarry Creeper Join Date: Apr 2010 Location: virginia beach
| got a question??? need help
i started out with a crawler king. not good enough. lol. so i made a custom chassis based off offroader5's design widow. i used a stampede tranny and the setup and layout is good. my problem is i am having extreme twisting issues. the chassis is twisting. should i change out the shocks and springs? its really annoying how much it is twisting. i am currently using the stock crawler king suspension, i am thinking that is the problem. thanks ppls for the help
09-15-2010, 05:23 PM | #2 |
Your shocks should probably be oriented more vertical and use stiffer rear springs along with a little extra preload on the shock on the side that the chassis twists to. Photos of your setup would be helpful.
09-15-2010, 07:42 PM | #3 |
| http://www.hobzob.com/album/view/p/r.../widow_chassis pics of my set up. more of a vertical suspension is kinda hard to do. |
09-16-2010, 02:00 PM | #4 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
do you have cross bars inbetween the plates.
09-16-2010, 02:26 PM | #5 |
yes i have cross members
09-16-2010, 03:04 PM | #6 |
Quarry Creeper Join Date: Sep 2009 Location: Scottsdale
The only solution to the actual frame twisting is stregth. More stratigic bracins, thicker/stiffer side plates, etc. Or you just just call it a torsion chassis |
09-16-2010, 03:22 PM | #7 |
Pebble Pounder Join Date: Jun 2010 Location: pelham
What did you make your chassis plates out of?
09-16-2010, 07:53 PM | #8 |
polypropylene
09-16-2010, 07:54 PM | #9 |
polypropylene i just locked the diffs in my tranny and it seemed to help a lil also |
