10-05-2010, 05:11 PM | #1 |
Quarry Creeper Join Date: Nov 2006 Location: omaha
| RC hydraulic ram
Is there such a thing as an rc hydraulic ram. I am wanting to build a scale dump truck and I want a ram to lift the dump. I can find a linear actualtor that is as little as 7", but its like $90. I was wanting somthing a little cheaper, thanks.
10-05-2010, 05:22 PM | #2 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
JIA built a hydrolic setup using some old TLT shocks... I think the thread is "hydraulics made easy" or something similar
10-05-2010, 05:55 PM | #3 |
Pebble Pounder Join Date: Dec 2008 Location: vidor
go to gardentrucking.com they have real hyd. systems for scale stuff like a dump truck but its not cheap at all lol
10-05-2010, 07:18 PM | #4 |
Rock Crawler Join Date: Oct 2009 Location: home town marsing
10-05-2010, 08:30 PM | #5 |
| Real hydraulics will cost you near $1000.
10-05-2010, 08:44 PM | #6 |
Good god all mighty. Are you serious josh? If thats the case, I will go totaly hokey and some how use a winch to raise it. I hope there will be a different allternative. |
10-05-2010, 09:03 PM | #7 |
| Not even a little bit. A hydraulic system is complex, you need pumps, reservoirs, switches, rams, lines, etc. For real it will cost you $1000.
10-05-2010, 09:09 PM | #8 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
| take a 645 and mod it for continuous rotation then tap the output shaft for M3 or M4 and secure a piece of M3/M4 threaded rod into the output shaft with a lock nut against the output shaft. Use a sleeve nut and some inginuity to make a draw screw set up with an arm that it pulls or pushes to dump.
10-05-2010, 09:44 PM | #9 | |
you must not know me very well, So what I am getting at is. Can you put that in even lamer terms than that. Think of it as explaining it to a 10 year old. Im slow when it comes to words to a picture in my head. hahah thanks | |
10-05-2010, 09:51 PM | #10 | ||
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
My rig has a pump, reservoir, 4 rams, control valves, ect... | ||
10-05-2010, 09:57 PM | #11 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
10-06-2010, 12:52 AM | #12 |
Pebble Pounder Join Date: Feb 2005 Location: Chandler, AZ
The dumptruck kit is only $300 ish. It uses a bi-directional pump and a resevior. It doesn't have any valves.
