03-05-2006, 11:07 AM | #1 |
Newbie Join Date: Oct 2004
| weird problem, front axle will not rotate backwards
Ok, so here's the probem, when I drive forward, all four wheels turn forward, but when I drive in reverse, only the rear wheels turn backwards and the front wheels stay locked. Any help would be appreciated.
03-05-2006, 11:20 AM | #2 |
Quarry Creeper Join Date: Aug 2005 Location: On the yellow dummy dumper
03-05-2006, 11:25 AM | #3 | |
RCC Addict Join Date: Sep 2005 Location: Lehi
03-05-2006, 11:45 AM | #4 |
I haven't got my fun out of it yet. But if I was going to do that I, I would just play crash up derby with it aginst my savage 25. |
03-05-2006, 01:45 PM | #5 |
Quarry Creeper Join Date: Jan 2006 Location: Ukiah, CA. (nor cal)
did you check out all the wires sounds like you may have lost a connection somewhere ??
03-05-2006, 02:06 PM | #6 |
Yes, I checked all the wires, motor, chip/esc every thing looks good. I think it must be the chip/esc, but I'm no expert.
03-05-2006, 07:34 PM | #7 |
Rock Stacker Join Date: Dec 2005 Location: usa
yep, its the board. did u solder on it? if so its toast i would just return it cause nylint tkaes for ever to get u a new one i called jan. 5th and its like march 5th and i dont have a new board |
03-05-2006, 07:44 PM | #8 |
Newbie Join Date: Jan 2006 Location: St. Louis
that's not good to hear hotchi, cuzz I just started having that exact same problem, except its going forward that the axle stops, reverse still works fine. The only thing I noticed was the front wheels started spinning slower. Then next time I ran it the front axle just crapped out. But it makes no sense that reverse works fine but forward does not. Time to call Nylint, Take a number and get in line... |
03-05-2006, 09:44 PM | #9 | |
03-06-2006, 07:25 AM | #10 |
did it work when u got it? if yea its proly just it getting warn out.if u have a receipt u get to the the top of the list at nylint. and u wont get threw on the customer service # call the main funrise #, when it picks up go to the operator and tell them u have been trying to get threw to customer service but u can get threw and they will connect u in about 30 secounds lol |
03-07-2006, 04:36 PM | #11 |
Thanks for the replys, but I just ended up emailing Funrise two days ago and the same day I got one back saying they would send my replacment ASAP. And yes it did work when I got it. |
03-14-2006, 04:58 PM | #12 |
Pebble Pounder Join Date: Mar 2006 Location: Placerville
Good to know, I soldered on mine and accidentally shorted it out...would've been fine if I hadn't run it that way...I noticed it was bad when it started smoking! Time for a new board.
