10-14-2010, 10:28 AM | #1 |
RCC Addict Join Date: May 2010 Location: The heart of the south
| Wheelie King Tranny Help
I bought a used Hilift from another member, he did a nice job on it and had converted it to a Wheelie King tranny. I did very little work on it but recently decided to rebuild it as a dedicated mud truck. I put a water proof VXL system in it and plan to run on 3S. It has 2.2 Slingers on weighted wheels. When I was running this on 2S and a Traxxas Titan motor with the stock Traxxas ESC, I had no issues at all, and it was fairly capable. Now with the new config if I slam the throttle i get some bad clicking. If there was a slipper in it, I would think it was loose, but I don't see one. It also does not sound like a typicle thrown tooth. So I am looking for a little advice. With WK trannys and even with HiLifts axles, is there a weak point I should look to? Should I just replace all the gears in the Wk as a precaution? I am going to tear it down this weekend and will replace anything I find broken but if it is best, I can replace all the gears (4 I think). Or as a second option, I am replacing a stock SCX10 tranny with a summit tranny soon, maybe I should look to move the SCX10 one to the HiLift. Any advice or help would be appreciated. |
10-14-2010, 11:19 AM | #2 |
Rock Crawler Join Date: Feb 2008 Location: Nebraska
There is kind of a cheap slipper in there. The middle gear in the transmission is two pieces which are held together with a spring. Once it starts slipping, it will continue to slip. What I did with mine was take the transmission apart and screw these pieces of the middle gear together.
10-14-2010, 03:58 PM | #3 |
Quarry Creeper Join Date: May 2004 Location: SW of Chicago
Look through the stickys and other threads in the Wheely King section for all kinks of info on the issue. Here's the slipper gear thread to get you started: WK Tranny Fix |
