View Poll Results: Can a 2.2 cane clod be compworthy or should I snag some cheap bully's | |||
yes , you already have the clods . DO it dammit | 6 | 60.00% | |
bully your way to the top. | 4 | 40.00% | |
Voters: 10. You may not vote on this poll |
10-27-2010, 12:40 AM | #1 |
Rock Crawler Join Date: Feb 2010 Location: Sturgis
| Is it worth building a 2.2 clod cane
I have a chance to build a 2.2 clod cane for the same price I can buy a set of bully axles . The clod axles will have aluminum front tubes and knuckles and metals lockers front and rear , stock rear tubes with straight axle mod . the bully axles are used but turn smooth. I already have a pimp cane on the way , so my question is should I continue with my 2.2 clod build or buy me some bully's . can the 2.2 cane be competetive? Im willing to practice and learn to drive.
10-27-2010, 07:06 AM | #2 |
IMO, the clod axles are big for a 2.2. Their diff clearance is pretty low. The Pimp Cane chassis works quite well. It will require a bit of a driving style change if you've never driven one. They can climb steep ledges and overhangs like no other! |
10-27-2010, 11:43 AM | #3 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
you know, i have been wondering the same exact thing. i have a pair of old clod axles that literally need EVERYTHING replaced except the gears... i was thinking going super with them, buuut, i am also thinking 2.2 as well.... |
10-27-2010, 11:52 AM | #4 |
I built a 2.2 Clod awhile back, PASS.
10-27-2010, 12:54 PM | #5 |
10-27-2010, 01:00 PM | #6 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
No. Not if your intention is to compete with it. I speak from experience. Browse this build thread for more info: The rebuilding of The Grunt (2.2 pimp cane clod) Now if you simply want to bash with it, as long as you keep it light weight, run a 14inch wheel base, and some decently tall tires, you will have a blast! The ground clearance from a pimp cane is incredible and it makes impossible ledges and break overs easily. But with the way crawling is advancing in design, there is no way a 2.2 clod will compete against a berg or XR10, or even a well tuned shafty. |
10-27-2010, 01:50 PM | #7 |
10-27-2010, 06:38 PM | #8 |
well Im in too deep now . I'm just gonna have to build it . I haven thad a crawler in a year so It sohould be easy to adapt to since I dont have to change up driving styles. Its gonna be beefy enough to turn into a super when I have enough $$$ for a bully/berg roller
