03-09-2006, 09:20 PM | #1 |
Rock Stacker Join Date: Jan 2006 Location: Bayside Queens, NY
| Please help with Clearance issues !!!!
Before I cut the front of my new tube chassis off, to redo it.... Can someone please tell me what is the IDEAL clearance is, between the Top Links and the Bottom (underside) of the chassis ? Front and Rear..... I think the nose of my new tube chassis might be angled down a little too much, and I might have issues with the top links hitting the underside of the chassis during shock compression and articulation.... Thanks.....
03-09-2006, 09:44 PM | #2 | |
You're asking a question that can have a million answers. There is no ideal clearance, although I'm still unsure of what your asking about. Links are mounting in so many different ways it's silly. Every chassis is different and everyone runs a different setup. Oh yeah, post a picture, words can only help us so far. Use the web to your advantage, post pictures!! | |
03-10-2006, 07:23 AM | #3 |
| Photo....
This is a shot I took to show how close the front axle is to the underside of the front chassis.....
03-10-2006, 07:26 AM | #4 |
| Photo
Here is another photo... The front end is almost touching the top of the axles....
03-10-2006, 04:28 PM | #5 |
RCC Addict Join Date: Dec 2004 Location: Central NY
You should straighten the fron out instead of having it droop down.
03-10-2006, 09:40 PM | #6 |
Although the chassis design is a bit off of the "norm".. I don't see much problem. Bring the front axle in a bit closer to the center of the chassis and extend out the rear an equal amount. You'll want a 40/60 setup or in your case you might push it and go with a 30/70 setup once you install/build links. |
03-10-2006, 11:59 PM | #7 |
Rock Crawler Join Date: May 2005 Location: omaha
Try making the front articulate only. I don't know how good it would handle, but it is an idea.
03-11-2006, 05:38 AM | #8 |
| Axles Placement
That is what I built it around... The front Drive shaft is an inch shorter than the Rear.. In the photo you cant tell that because they are just sitting on the table not attached to anything.. (they must have moved before i took the photo.) I think my main concern is the underside of the chassis is too close to where the top links mount and will not allow good articulation or shock compression... Has anyone ever bent tubing after the Frame was assembled ? Or should I cut off the front half and redesign ? If I do cut the front off now wont it twist the frame up ?
03-12-2006, 06:50 PM | #9 |
Pebble Pounder Join Date: Sep 2004 Location: Charlotte
Just build the rig around your suspensions full compression. If you want more uptravel/downtravel then change the mounting locations/spring rates on your shocks. Keeping the weight down low is always a good thing, and building it at full compression you can do your steering and links to make sure you wont have binding issues. Goodluck on the project, tube chassis looks good. Leach |
