11-04-2010, 09:53 PM | #1 |
Rock Stacker Join Date: Aug 2005 Location: olyWA
| Best Application for a Rock Racer?
I'm looking for a more dual-purpose rig, like a KOH style rig that can hit the go-fast stuff then slow down and hit the rocks. What would be a good application for this? I've seen a few different approaches but most are basically shaft driven rigs with good suspension and either a Summit trans or use wheelspeed to get up most obstacles. I know some people would start with a tube chassis but I'm not sure if it would hold up. I've only had a handful of crawlers and I'm addicted to fast stuff too so I really want to build a dual-purpose rig. I've thought of the Summit but it's more of a monster truck with lockers and low range. Fun, but not realistic and anybody can snag one off the shelf. Thoughts? I want something similar to the Jimmy's 4x4 rigs- |
11-04-2010, 10:02 PM | #2 |
Why wouldn't a tube chassis hold up? When built properly, I don't think you could get anything stronger...
11-04-2010, 10:03 PM | #3 |
Quarry Creeper Join Date: Feb 2010 Location: muskegon
search the scale rigs section it should give you some good ideas. my suggestion, (and this is what I would do if I had the money) is get a summit tranny and a set of Gmade R1 axles, grab some brake tubing and a welder and let the sparks fly. or buy a chassis from someone.
11-04-2010, 10:04 PM | #4 |
11-04-2010, 10:06 PM | #5 |
Pebble Pounder Join Date: Oct 2010 Location: Dunedin FL
Plus all the 1:1 rigs you're talkin about use some sort of tube chassis
11-04-2010, 10:06 PM | #6 | |
http://www.junfac.com/shop/index.php...roducts_id=336 | |
11-04-2010, 10:07 PM | #7 |
11-04-2010, 10:09 PM | #8 | |
XRRA Rock Buggy | |
11-04-2010, 10:20 PM | #9 |
Very nice start! What are you using to weld it together? I noticed you said solder, do you use a torch and some special flux?
11-04-2010, 10:28 PM | #10 |
MAPP gas torch and safety silv 56.
11-04-2010, 10:51 PM | #11 |
RCC Addict Join Date: Jul 2006 Location: Pasadena
TLDNR. I will answer the title though, obviously, to race against rocks.
11-04-2010, 10:53 PM | #12 |
11-04-2010, 11:04 PM | #13 |
11-04-2010, 11:04 PM | #14 |
Wow, really pushing the boundaries these days huh? However much I like when people think outside the box, these guys goes a little too far sometimes. It's like when we first started running large outer diameter rings. Oh man...
11-05-2010, 12:29 AM | #15 |
How about the MOA rigs? Can they still be competitive without an actual transmission?
11-05-2010, 07:52 AM | #16 |
11-05-2010, 08:27 AM | #17 |
11-05-2010, 08:28 AM | #18 |
11-05-2010, 08:58 AM | #19 |
Rock Crawler Join Date: Jan 2007 Location: in my bubble
A tube chassis that is designed correclty, and brazed with silve solder and Flux woulod have more strength that you would EVER need. Brazing is pretty easy, just takes a little practice. There are some amazing tube chassis builders on here. It might be worth contacting them. You'll go through far more lexan bodies with a rock racer than a tuber. |
11-05-2010, 08:59 AM | #20 |
your welcome thats me iceman the screw up LOL |
