11-12-2010, 05:46 PM | #1 |
Rock Stacker Join Date: Oct 2010 Location: SLC
| delrin noodle
im new here but i just ordered up some vp 4 link plates so i was planning on making my own links. today i went to the plastic shop and found some delrin rod. it was very flexible. not what i imagined so i left it there. am i looking for another name? i saw there is some delrin/acetal composite. what is the name of that.? thanks
11-12-2010, 05:52 PM | #2 |
Rock Crawler Join Date: Feb 2010 Location: Hayesville
What size did you have? 5/16 works well for upper links and when you cut it down to size its pretty stiff.
11-12-2010, 05:55 PM | #3 |
looked at 5/16 and 3/8. i was expecting stiff material. it did not take much pressure to bend the short piece.
11-12-2010, 05:57 PM | #4 |
3/8 is real thick I use that on my lower links.
11-12-2010, 06:11 PM | #5 |
Rock Crawler Join Date: Nov 2006 Location: Albuquerque
The flexibility is not really an issue once you cut them to length. Also, a little flex is good because in a tumble, it helps absorb some of the shock.
11-12-2010, 06:32 PM | #6 |
11-12-2010, 06:53 PM | #7 | |
RCC Addict Join Date: Jun 2008 Location: Fresno
i use 1/2 inch delrin rod on my super's lower links. when i bought it at 5 foot lengths it seemed reallyy wobbly. but at 10-12 inches i had to hold one end down on a bench vice and the other w/ a 16" socket wrench to see if it would give | |
11-12-2010, 08:55 PM | #8 |
i wonder if the composite delrin is out there being sold as "delrin"
11-12-2010, 09:23 PM | #9 |
I think that you are referring to fiberglass reinforced delrin. No it is not being confused with regular delrin and no you dont want to use it. It is a huge pain in the butt to work with compared to regular delrin. How long of links are you trying to make here? Delrin is very strong and rigid compared to most plastics, if you dont like delrin then its time to go to some metal. |
11-12-2010, 09:28 PM | #10 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
They make glass filled Delrin. Mcmaster Carr has it in rods. /8 is the smallest size. Not sure what the ends would be like if shaped. Should be stiffer. White only. http://www.mcmaster.com/#acetal/=9p0ryc |
11-12-2010, 10:13 PM | #11 |
I wanna be Dave Join Date: Oct 2007 Location: 801
"acetal" is the technical name for delrin. Atleast that's what all my plastic suppliers have told me. |
11-12-2010, 10:50 PM | #12 |
11-13-2010, 01:53 AM | #13 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
I have made several set of upper and lower links out of Delrin with great success using both 5/16" and 3/8" rod, like said before 5/16" works great for upper links, for lowers I am currently using 5/16" drilled all the way through with threaded 8/32" rod all the way through and Revo rod ends, it has been working great, with out the rod all the way through them I did start to notice them beginning to warp a little, rear links are machined HC which are nice and stiff as well, I think as long as you go with 5/16" diameter or larger you will be fine.
11-15-2010, 07:52 PM | #14 |
well ill buy some and give it a whirl. im going to try to put a bend in them too. thanks
11-16-2010, 06:55 AM | #15 |
Rock Crawler Join Date: Apr 2008 Location: Lexington
One other thing to consider when it comes to people making delrin links is that a lot use allthread as the link material and sleeve it with delrin.
