11-21-2010, 04:58 AM | #1 |
Quarry Creeper Join Date: Feb 2005 Location: Australia
| Berg / 300 / VP / RCI OTA
Hey guys I remember seeing some comments in my forum surfing but can't seem to re-locate them with a search...... I have the 300s, VP Hi steer knuckles and RCI OTA steering setup. Knuckles are facing forward. I had no problems with the setup......until recently. I modified the front end with wider hubs to gain some clearance between the steering arm and my tyres and also my tyres and springs at full lock. The problem I have now is at full lock (on throttle) I get MASSIVE wheel shake. It wasn't there with the previous VP hubs (narrowest offset). What's the story ? Is there a fix ? Or do I go back to the narrow offset hubs. Last edited by Shorty40; 11-22-2010 at 05:19 AM. |
11-21-2010, 12:46 PM | #2 | |
I copied this from another thread for you. Quote:
11-22-2010, 05:19 AM | #3 |
So I need zero Ackerman knuckles ? But this steering kit was designed for the VP knuckles. That sucks |
11-22-2010, 06:31 AM | #4 |
Rock Crawler Join Date: Dec 2009 Location: Jersey Strong!
If the CVD's are hitting their limits, you could turn down your EPAs.
11-22-2010, 07:12 AM | #5 |
Have you pulled apart the CVDs to see if they are damaged? Since you are getting more throw now, it could be that any damage wasnt noticable before.
11-22-2010, 09:13 AM | #6 |
I had the same problem. Check the CVD pins, mine were a bit fed up so I replaced them and made sure the slots were smooth. It helped out a ton. Also make sure that your knuckle bushings (the little top hat guys) fit well in your kuckles. If there is slop there then it really contributes to this problem, locktite the screws tight also...Once mine loosen up the front right tire goes crazy.
11-22-2010, 11:30 PM | #7 |
The CVDs are almost new. I don't get the wheel shudder/shake with the narrowest hubs on the SLWs. Only when I put the wider hubs on. |
11-23-2010, 12:53 AM | #8 | |
Is there any wobble in your knuckles? Can you shake them at all? | |
11-24-2010, 04:12 AM | #9 |
I took the knuckles off and cleaned the CVDs. They rotate smoother in hand. But I put them in the axle and power it up and they grind and vibrate. And I don't think I am near maximum angle of the CVD. I tried to disassemble them but I can't get the ring off. The grooves for the pin appear to be clean and clear (I WD40'd the crap out of them). Think maybe buggered CVDs ??? But they are practically new. EDIT - It is doing this no matter which hubs I use. So it isn't the OTA steering, the hubs or the knuckles. I am confident it is an issue with the CVDs. Last edited by Shorty40; 11-24-2010 at 04:23 AM. |
11-24-2010, 07:17 AM | #10 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
Do you have a bent axle tube or is the actual axle shaft bent?
11-24-2010, 11:18 PM | #11 |
Pretty sure neither are bent as they run true with the wheels at straight ahead. The vibration appears from about half lock and increases as the lock increases.
11-25-2010, 12:54 AM | #12 |
11-25-2010, 04:01 AM | #13 |
Way more violent than that ! Trying to upload a short vid now |
11-25-2010, 04:10 AM | #14 |
11-25-2010, 05:12 PM | #15 |
I think your just looks worse because you were spinning them faster. Here is what helped mine. Making sure the knuckles had no play on the bushings and the screws are always tight. Putting 2 orings around the balls in the ball ends to add some resistance. Moved the tie rod to the closest hole to the knuckle mounting hole. After all that my problem was solved. The problem happens because of the angles in the steering linkage. When the steering is at the lock the inside knuckle (Worse on the right side) is turned so far that the tie rod can pivot and move that knuckle because the knuckle follows closely enough to the arc that the tie rod is on. The shorter the link is from the servo to the tie rod the less you will notice this issue and adding the o-rings quiets down the movement. Any extra slop in the knuckle bushings allows the knuckle to flex outward or inward allowing the angle to change as the tie rod swings. |
