11-23-2010, 04:38 PM | #1 |
Rock Stacker Join Date: Nov 2007 Location: Dover, De
| Rustler Tranny...
I have an Rustler tranny, MFM chassis, and a pair of WK axles, so I am gonna throw together another rig. I am wondering what size pinion I should run with a 55t motor? Also, I am gonna run Traxxas shocks...what springs should I use?
11-23-2010, 05:36 PM | #2 |
Rock Stacker Join Date: Nov 2006 Location: Eugene
what are your plans for the rig? Do you want to go real slow or have some wheel speed. What spur gear is on it? I use red springs on my shox but you will have to find what works for your application. The weight of your rig will matter to on the spring choice
11-23-2010, 06:23 PM | #3 |
I would like a little wheel speed, but more trail/crawling than anything. It is a newer style tranny, not sure what the stock spur is? I will try a few different springs once I figure out the rest of it!
11-23-2010, 06:46 PM | #4 | |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
That is most common for scale trucks, provides a good top end while maintaining low end control. the Crawler combo's from tekin are the best bang for the buck | |
11-24-2010, 04:43 AM | #5 |
i will check them out!
11-25-2010, 02:53 AM | #6 |
This is her... |
11-25-2010, 03:05 AM | #7 |
Almost forgot...what weight fluid does everyone use in their shocks?
11-26-2010, 08:35 AM | #8 |
Pebble Pounder Join Date: Sep 2010 Location: Lava Lands
| shock setup
You need to lower that sucker. try running a semi droop setup w/ soft internal springs above and below the shock piston with some 50w/ fr & 70w in the rear. Maybe throw the battery on the chassis. I run this setup on one of my scalers and limits the travel somewhat but stays planted and level, most people have way to much travel anyway.
11-27-2010, 04:42 AM | #9 |
I lowered her a little. 35w in the front, 45w in the back. |
