11-26-2010, 12:47 AM | #1 |
Newbie Join Date: Oct 2010 Location: milpitas
| Drivelines
im building a costum tube truggy with ax10 axels and trans and my total lenght came out to 15.5 inches yea i know shes a big one, but the problem is that i cant seem to fine a driveline to fit, its sitting about 6 inches from u-joint on the axel and the u-joint on the trans. dose anyone know where they sell them that long? thank you
11-26-2010, 09:42 AM | #2 |
You can make them. I liked the Junfac ones for a bit. They were just a touch short for me though so I had to cut and weld so its a bit longer. If you need help let me know. |
11-26-2010, 09:46 AM | #3 |
I wanna be Dave Join Date: Oct 2007 Location: 801
Just buy an extra set of axial or traxxas drivelines. You will glue the externally splined shaft into one of the female shafts and cut off the yoke on the one you just glued in and then use another female shaft on the other side. So you have the female end of the driveline on both sides with the externally splined one in the center. |
11-26-2010, 10:09 AM | #4 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
RC4WD has long punisher shafts ........bob .... |
11-26-2010, 12:33 PM | #5 |
thanks for all the help ill look into the rc4wd ones
