03-16-2006, 10:19 PM | #1 |
RCC Addict Join Date: Jul 2005 Location: Provo
| my 1:18 jeep crawler
well it started out as a trail rig crawler but all my buddies started moddin theirs so i kinda had too Mods: Cut tires 3 coils cut in rear 4 coils cut in front tummy tucked rear axle rotated 90 degrees (amazing mode) extended wheel base battery relocated to front stinger modified spare tire with aluminum plates krlon fushion paint 200bbs in each front tire Comp cut rear Shaved 1/4" off body posts to lower cog Before: During: After: Rear axle 90 degrees: PLEASE NOTE i had to add links to keep axle from walking side to side and my shock mounts are only temporarly! So what do ya guys think? Last edited by Got Rocks?; 03-16-2006 at 10:30 PM. |
03-16-2006, 10:21 PM | #2 |
Another pic! the front end is not extended in these pics |
03-16-2006, 10:56 PM | #3 |
here is a link to more pics http://photobucket.com/albums/f48/GotRocks4x4/?sc=1 |
03-17-2006, 09:09 AM | #4 |
RCC Addict Join Date: Sep 2005 Location: Lehi
how did you connect the axle to the 'links'? It lookes like it hasn't even been connected....
03-17-2006, 10:59 AM | #5 |
i have a long screw goin through it works great! onlt time will tell how it holds up but i had it bindin pretty good i did crack the axle case but it could have been avoided if i would have used a washer so not i have two links that conect to the chassis and axle ill snap some pics |
03-17-2006, 11:29 AM | #6 |
here is a couple more pics |
03-17-2006, 12:25 PM | #7 |
That is pretty sweet....Maybe I will keep my 1/18 EDIT: I just noticed that it lookes like you are missing a screw on the back tire in that pic....What is that about???:neutral: Last edited by Going Up!; 03-17-2006 at 12:51 PM. |
03-17-2006, 03:14 PM | #8 | |
03-17-2006, 10:49 PM | #9 | |
03-17-2006, 11:01 PM | #10 |
well i got very bored so i thought hey this is a comp nylint now so lets make it look like one! |
03-18-2006, 01:07 AM | #11 |
the only thing id change is to move the rear link becasue i get caught on it but ohh well i need another project... im running out of stuff to do! |
03-18-2006, 08:30 AM | #12 |
| I like the crawler....Pretty sweeet!
03-18-2006, 09:35 AM | #13 | |
Rock Crawler Join Date: Nov 2005 Location: Rock-throwing country
03-18-2006, 11:28 AM | #14 | |
03-20-2006, 09:01 PM | #15 |
well i moved shocks back works great now all my weight is up front i can balance it on my finger on the front center link thats good news for me! i am going to move rear axle back a little and cut more off bottom the rear axle 90 works great and is lastin well:-P ill snap some pics
03-22-2006, 02:20 PM | #16 |
well here are some updated pics i have exactly 1in chopped off bottom now can climb curb again even with lowered suspension and extended wheelbase! |
03-22-2006, 02:56 PM | #17 |
Man, I like it!! |
03-22-2006, 03:10 PM | #18 |
Pebble Pounder Join Date: Mar 2006 Location: igloo, Alaska
| Wires out of axles
I have slid a washer into the peice that goes through the axle and the arm that is mounted the the 2 swing arms. I also slid on a washer onto the peice that goes through the axle and used a longer screw to hold it all together this worked great because now the axle can now hit the body without the inboarded shocks hitting but the wire is still short and the front wire is REALY short. Did u just oull and get more or solder on more wire?
03-22-2006, 03:39 PM | #19 |
nope! im tummy tucked are you?
03-22-2006, 04:37 PM | #20 |
Naw im not TTd but nvm i just was wondering if i soldered on more wire or pulled some out i opened it up after i did the front again ind found that there is alot of wire hidden under that cover i pulled out wut i needed and now have enough did my other post make sense or should i try to take pics?
