Thread: 3mm threaded spacers........
Old 02-18-2011, 12:13 PM   #1
Default 3mm threaded spacers........
i'm looking for a vendor here that had a spacer kit for sale that made the spacers and put them in a kit....but i need him or any vendor that can make custom length threaded spacers in 3mm thread....search turned up crap as it seems like it does all the time ....i did many search's with spacers only and what i thought were reladed words, got a ton of build threads with the word spacers and other words i used in them ....but nothing on any vendor doing spacers, even searched in vendors section with the same dull results ....what i'm looking for are 14 custom made 3mm threaded spacers that are 13.40mm long and no bigger then 6mm O.D. 5mm O.D. would be the tits HELP ! ! ! ........bob
bob1961 is offline   Reply With Quote
Old 02-18-2011, 01:16 PM   #2
So you want .5275 long pieces drilled and tapped on both ends or do want a male thread on the ends?
Cave Dave is offline   Reply With Quote
Old 02-18-2011, 05:11 PM   #3
yes .5275" and no male ends, just threaded pipe/spacers i can use a button head screw from both sides on....i need them for this....
so i don't need to use a tube spacer with a nut and bolt, kinda looks cleaner that way ....let me know, thx........bob
Old 02-18-2011, 05:23 PM   #4
Smallparts.com might have what you need.
MonkeyRiver is offline   Reply With Quote
Old 02-18-2011, 05:25 PM   #5
The kind of spacer you're describing is called a standoff.
Old 02-18-2011, 05:44 PM   #6
yeah i know they are standoff's but the only ones i can find are 10mm and 15mm on both sides of the scale i need of 13.40mm....i'll look at small parts and see, thx ........bob
Old 02-18-2011, 05:51 PM   #7
so buy some 15mm posts and trim 1.6mm off and rethread
2500hdon37s is offline   Reply With Quote
Old 02-18-2011, 08:23 PM   #8
yeah i looked at the standoff's i have and they have a bigger end then the middle part that is too big to use where i need them....yeah i bought some 98mm threaded alum pipe "AKA" axial 6mm links and cut them down to what i needed, but lots of file work to get them the same size now ........bob
Old 02-19-2011, 08:53 AM   #9
Cheap/easy would be to buy the shorter standoffs, then add thin flat washers between the plate & standoff to get the correct length.
Charlie-III is offline   Reply With Quote
Old 02-19-2011, 09:00 AM   #10
yeah i thought bout that too, but i want a cleaner look....i have a plan of using 3/16" brakeline and 6-32 screws if they aren't too much bigger then 3mm hardware....i don't have much room to enlarge the screw holes on the side plates.........bob
Old 02-19-2011, 11:42 AM   #11
I could make the 1/4" OD hollow aluminum tubes to your length, but I'll be dammed if I will thread them.......
I gotta go back and "make chips" on your spool (Calvin is away this weekend....I can get "my" stuff done........)
Old 02-19-2011, 11:49 AM   #12
I would contact a local machine shop if you are really needing the parts to be that specific and dont have the ability to make the parts your self.
killswitch is offline   Reply With Quote
Old 02-19-2011, 12:31 PM   #13
Originally Posted by killswitch View Post
I would contact a local machine shop if you are really needing the parts to be that specific and don't have the ability to make the parts your self.
bob has one......."me"..........
We are both from GSRCRC.....
Old 02-19-2011, 05:00 PM   #14
i have the threaded alum pipe axial makes cut to size now, 8 i need for my trans and transfer case spacers....i just need to hand file them to 13.40mm and tap the threads in the ones i cut past the threads ....i just look at some 6-32 hardware/threaded rod and it's not much bigger then 3mm hardware, so now i might go with threading 3/16" brake line to 6-32 screws and have smaller dia spacers .........bob
Old 02-20-2011, 08:45 AM   #15
I gotta ask... why not build it with 1/2" channel stock and shim the gears to fit?. Or you could easily plunge cut a box from bar stock if you have access to a vert mill.
Old 02-20-2011, 09:38 AM   #16
don't have access to fine equipment like that, i can use it....dril press and hand tools, it's the MacGyver in me sorry ........bob
Old 02-23-2011, 10:20 PM   #17
Sorry, thought you had access to machine tools.
