12-07-2010, 05:56 AM | #1 |
Rock Crawler Join Date: May 2010 Location: CRAWlORADO
| position of front and rear upper links?
ok I have searched and cannot find what i am looking for. Is it better to run front upper links lower than the rear upper links? if so how does it help? |
12-07-2010, 06:02 AM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
the front upper links should be low on the axle and high on the chassis,,,and the rear upper links should be low on the chassis and high on the axle...this combination creates anti-squat. if you run the front link higher on hte axle it will pull the front of the chassis down. if you run the rear links higher on the chassis it pulls the chassis down which adds to torque twist along with chassis roll and roll center.
12-07-2010, 06:06 AM | #3 |
ok thanks thomas I should of known that makes sence
12-07-2010, 06:09 AM | #4 |
thats how i set your rig up....do you want it to do something else?
12-07-2010, 06:11 AM | #5 |
no,,, I have not messed with the set up I do belife that the links are in the same position as eachother
12-07-2010, 06:14 AM | #6 |
I do see some people with front lower and rear higher so I just confused myself
12-07-2010, 06:14 AM | #7 |
are you goin to the keg crawl saturday? if so we can work on your rig then.
12-07-2010, 06:16 AM | #8 |
12-07-2010, 06:16 AM | #9 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Because of chassis and axle differences as well as terrain, you will always see varying info on what is right and what is wrong. Only way to tell for yourself will be trial and error with your truck and your terrain.
12-07-2010, 06:16 AM | #10 |
I wish but I promissed my ol lady that I will spend the weekend with her. gotta make her happy to make me happy you know what i mean
12-07-2010, 06:18 AM | #11 |
I was also going off your drawing on your ts and ts and their in the same position on the chassis thomas
