12-20-2010, 10:38 PM | #1 |
Pebble Pounder Join Date: Dec 2008 Location: guam
| Losi MRC axles
Will losi MRC axles fit on an scx10?
12-21-2010, 12:00 AM | #2 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
most likely not, since there is a huge difference between the scales.
12-21-2010, 01:12 AM | #3 |
ohh yeah i forgot Thanks
12-21-2010, 01:15 AM | #4 |
however i could be wrong.. heres a measure of the MRC axle 89.5mm |
12-21-2010, 09:07 AM | #5 |
Rock Crawler Join Date: May 2009 Location: 354
yes it will, with some creativity, although it's not an SCX10 chassis it is the exact replica of it that I made. I used the axles and tranny for this build and Traxxas Stampede driveshaft and wheel extenders |
12-21-2010, 01:19 PM | #6 |
| Yes, it is possible, but it is not a simple bolt-on project. • You need to make custome links with 3mm on one end and 2mm on the axle side • You'll need to decide what tranny you are going to use. If you use the Axial tranny you'll need to make drive shafts to go to the axles. If you use a MRC tranny you'll need to make a mount for it and extend the drive shafts. • You'll have to figure out what shocks you'll use and how to get them mounted up. |
12-22-2010, 10:22 AM | #7 |
Rock Stacker Join Date: Jan 2010 Location: Reading, United Kingdom
If you can make them work on a SCX it would be great as it would look real scale because the tires will be up under the arches |
12-22-2010, 11:04 AM | #8 |
