Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: upgrade electronics
Old 03-27-2006, 11:14 AM   #1
Default upgrade electronics
I have a 1/18 jeep and want to upgrade electronics to good rc electronics. is there a package deal out there that includes the controler,esc,servo and everything else needed to swap over? I want to use my cheap walmart crawler as a base for now and up grade axles,and everthing else later.anybody have a link to some good electronics??I'v read alot about doing this but I don't know what is good and what is bad??thanks for helping a newbie
toy 2 is offline   Reply With Quote
Old 03-27-2006, 12:57 PM   #2
as far as electronics you dont need anythign special for the nylint but if you plann on upgrading to a better crawler in the future keep in mind you will need a high torque servo/servos and a good esc.with that said they dint make a full system like that. they offer radio packages with beginer level esc and servos with a radio and reciever but nothing you would want o use in a good crawler. i would just buy a decent radio and servo for the nylint,get a cheap esc and then when its time to move onto a better cralwer just buy all new and keep the nylint as a stand by.
twisted is offline   Reply With Quote
Old 03-27-2006, 02:47 PM   #3
thanks for you help. I know I sound like an idiot but could you link me to some stuff that is cheap and good enough for the nylint. I don't know what radio will work with what servo and esc?? Thanks again for your help
Old 03-27-2006, 04:53 PM   #4
almost any radio will work as long as u can change out the crystals u will need at least a 2 channel reciver and a cheap esc with reverse make sure it has reverse because some dont u will also need a semi-high tourqe servo i say semi high cuz these nylints dont weigh much and shouldnt be hard to turn when u get this all done be careful cuz it will break way easy you have to be gentle and not rail on it all the time if u drive it right it should be easier to hold together cuz u can control wheel speed most people break things when theyre spinnin their tires and then sudenly get traction those 4 things should be all u need except a different battery pack im not sure if a hobby grade esc will run verry good off a 650 mAh pack but good luck and happy wheelin
plyr2k is offline   Reply With Quote
