01-18-2011, 02:50 PM | #1 |
Newbie Join Date: Dec 2010 Location: Austraila
| Slow go
Hi all I have a strange problem with my Exceed 1/10, Over the last few days when I have being driving it after a few min it starts to go very slow forward.....but is fine in reverse The ESC does not feel that hot at all!!!! Thanks all Omegaman |
01-18-2011, 04:32 PM | #2 |
first off it an exceed, my be the ESC or your RX is not set properly contact exceed and tell tell them your problem , good luck there hard to get a hold of had the same on mine and they never resolved the problem an told me to sell iy on EBAy not the beSt company to deal with GOOD LUCK AND THEN SELL IT |
01-19-2011, 08:53 PM | #3 |
Quarry Creeper Join Date: Sep 2010 Location: Berlin, VT
Dont sell it. Everything is fixable. When it starts to crawl forward, what happens when you turn back the throttle adjustment? Does it do anything? Worst case scenario is you put some new electronics in it. |
01-20-2011, 01:34 AM | #4 |
Hey Hyde Not selling yet After some advice from fellow forum members i got a new ESC (AMAX MODEL) today for my Exceed 1/10 installed it with no probs...but I must be doing something wrong! issue I have 1) On a slope, no brakes 2) Have to pull full throttle on Controller to wake up motor and move forward. What am I missing here... Thanks again |
01-21-2011, 02:11 PM | #5 |
RCC Addict Join Date: Jun 2010 Location: fort collins
i had the same problem with my ax10 rtc and i upgrader tx/rx to the dx3e and all problems were solved. also notice the upgraded esc didnt solve all problems i was having until i got controler unit. hope this helps
01-22-2011, 01:29 AM | #6 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
could just be the motors are crapping out on you. Also, dont the exceeds come with a program card? if so, program your dragbrake all the way up. about "waking" your ESC up.. your ESC could just be damaged. or it was previously in the brake mode. |
01-23-2011, 06:03 PM | #7 |
On a lot of esc's you have to set it up to work properly with your radio, otherwise you won't get proper throttle control. If you've already done it, try it again. Also, make sure your throttle trim in centered before doing this... One more thing: this should teach you a lesson about going cheap. Last edited by Duuuuuuuude; 01-23-2011 at 06:07 PM. |
