02-09-2011, 11:41 PM | #1 |
Newbie Join Date: Feb 2011 Location: longview
| Help with axial scx10 turning
I was wondering if anyone can help me find a way make my axial scx10 honcho turn sharper without getting four weel steering???
02-10-2011, 05:38 AM | #2 |
CVDs and high steer knuckles or a longer servo horn.
02-10-2011, 07:27 AM | #3 |
the biggest thing is to get the tie rod away from the differential when you turn all the way one direction. this is what limits the steering throw in stock form. any of the high steer knuckles will take care of this, but for the time being i have used some rod end balls to space the tie rod up. this will get you a good bit more steering, but in order to get more you will have to either go with some cvd's from axial, MIP, or super 300's...OR...if you have access to a drill press and the right size countersink bit...you can use it to shave the stub axle cup down so that they will allow you to turn all the way without binding up. hope that helps! |
02-10-2011, 08:32 AM | #4 |
were can i get those parts do you know any good websites.
02-10-2011, 09:34 AM | #5 |
Rock Crawler Join Date: Apr 2010 Location: Central FL
RPPHobby, TCSCrawlers, or many of our other fine supporting vendors.
02-10-2011, 10:31 AM | #6 |
