04-12-2006, 01:21 PM | #1 |
Quarry Creeper Join Date: Mar 2006 Location: ft. collins
| skid plates / slide rails
I have been working on low profile skid protection for the bottom of my rig. I noticed that the bottom of my axles were taking a beating. I don't do comps yet so losing 1/8 inch of clearance does not bother me. Aluminum did not work out well. I found a plastic that is moldable when heated and came up with this skid plate. It slides easy on rock and does not hang up. It also protects the motor area. Let me know what you think I also got an idea for slide rails for the sides. Seems to slide well. Let me know what you think. Last edited by dystance; 06-19-2006 at 07:46 PM. |
04-12-2006, 01:50 PM | #2 |
I wanna be Dave Join Date: Jan 2004
the diffs are the skids. no need for anything extra. |
04-12-2006, 02:19 PM | #3 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
You have a nice set of skids by far the best setup ones I have seen. But, I'm with DirkDigler on this one. Axle cases are cheap and take a long long time to wear out. |
04-14-2006, 07:36 AM | #4 |
Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
long time to ware out to never ware out.interesting concept.any way if it's not interfering then use it
04-14-2006, 10:24 AM | #5 |
1* Join Date: Dec 2005 Location: Ozarks
It looks like you used Kydex, at least that's what I've heard it called. I formed my skid last night for my Mantis chassis. It will cover the bottom and extend forward toward the axles. My driveshafts were getting beat to hell on the rocks and Kydex offered an easy solution.
04-15-2006, 06:26 PM | #6 |
Quarry Creeper Join Date: Nov 2005 Location: East Quogue
| I think its cool |
06-19-2006, 07:27 PM | #7 |
So after some testing, I have decided that I like the skid plates and the slide rails. Neither hangs up and I do not notice any down side. The skid plates are holding up great. I have a new body that I did some new slide rails on and really like them. I bent the lower portion of the body inward for clearance and then applied my slide rails. They are made from carpet transition strips (aluminum). They are applied with liquid nails, and seem to be solid. They do not hang up like the edge of the body does. Instead of the body edge catching and pulling, the slide guard keeps the edge rigid and it slides free more easily.
06-19-2006, 07:39 PM | #8 |
Quarry Creeper Join Date: Jun 2006 Location: L-Town
| Quote: |
06-19-2006, 07:51 PM | #9 |
We have a plastic supply house called Fort Collins Plastics. They have all types of plastic materials. It's not really a retail place. They mostly do fabrication and wholesale.
06-19-2006, 09:53 PM | #10 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
Those rocker panels look great |
06-20-2006, 02:44 PM | #11 |
Does wnyone else know where you can get the plastic you heat and can be molded, i have heard of others guys useing it to?
06-20-2006, 09:19 PM | #12 |
Ever heard of the internet......what the f*#k is the internet? Try this link: http://www.fortcollinsplastics.com/f...splastics.html Call them up and ask about it. I cannot remember the type of plastic, but they will know that of which you speak. Describe it as sheet plastic, black in color, textured on one side. It comes in several sizes, I used 1/8th inch thickness. I think he would ship it out, or at least give you the name for you to look for a sourse closer to your local. When/ if you find out the name, post it up on this thread. |
06-20-2006, 09:34 PM | #13 | |
06-20-2006, 09:36 PM | #14 |
My pleasure Quote from Silent Bob. What ya using the plastic for?
06-20-2006, 09:48 PM | #15 |
I have an NN chassis and i dont want to mount the ESC on the axle and i got a good idea to use the plastic as a mounting plate and mold it around the upper bar that connects the 2 chassis side plastes to gether.
06-20-2006, 10:05 PM | #16 |
Good idea. I also run the NN and use thin aluminum bent and attached to the side plates to mount the ESC and receiver. Same idea. Keep the electronics looking clean.
06-20-2006, 10:14 PM | #17 |
ya thats a great idea too, never thought about using that. I love the NN chassis.
09-29-2006, 11:47 AM | #18 | |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
09-29-2006, 03:15 PM | #19 | |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
It's called Kydex. Tower has it. | |
10-19-2006, 05:06 PM | #20 |
I finally got around to making the second version of my skid plates. I ran my rig for awhile without them, but I got BTA steering, and I thought it would be good to use a skid to prevent scraping along on the steering components. This time I used 1/16" thick material, ( it is ABS plastic ) and heated and shaped small areas at a time. This worked better that heating the whole piece in the oven and then trying to mold the whole thing. This version is much lower profile, only lost 1/16". I notice it slides over ledges easier with the skids, so I figure the compromise is worth it. The skid plate is attached using the two hole in the gear case as shown, and by molding the plastic over the nub on the motor mount area. |
