Thread: Don't buy links - build them!
Old 03-23-2011, 11:47 PM   #1
Default Don't buy links - build them!
Since I'm starting a new project I decided to see how hard (and expensive) it really is to build links for my AX10.
Cost:
1 pack of Traxxas Revo link ends (soooo much better than axial ends): $8.00
2 one foot lengths of 8/32 rod: $2.50
2 feet of stainless steel tube: $3.00
total cost $13.50 for homebuilt lowers versus $40 for axial parts at the LHS.
Also needed:
8/32 tap
tubing cutter
callipers (ideally)
demmel or saw for cutting rod
check out the stock axial 3mm thread compared to the 8/32 rod:
You can make them any length you want, Stainless won't snag on rocks the way Aluminum does, the Revo ends use metal balls and are way tougher, and if the 8/32 threads ever pull out you probably broke the rest of your rig anyway.
Tap the revo ends, measure and cut your rod to close to the length you need, adjust the length (you can unscrew the ends slightly to make the link longer or cut a bit more rod off to make them shorter), then measure the exposed rod and cut a length of tubing to sleeve it. Takes some time but it's not hard.
Mud Puppy is offline   Reply With Quote
Old 03-24-2011, 12:16 AM   #2
+1 on diy links. 1/4" brake line also works great over 8/32 all thread if you can't source stainless steel or want to buy everything locally. Delrin links are just as easy with JeepinDoug's drill bushings.
forbid89 is offline   Reply With Quote
Old 03-24-2011, 07:30 PM   #3
Yup that works.
This isn't really DIY but i'm sure a bunch of you old timers have those Traxxas steel links. They are the smooth silver 4mm, or longer black 4mm, can't remember part numbers. I like to chop the thread off the end, cut down the link to the proper length, and braze the thread back on. The links on my jk build are built that way.
dirk379 is offline   Reply With Quote
Old 03-24-2011, 07:40 PM   #4
i went with big dubro rod ends and solid rod that was .144" dia that threaded nice with 6-32....never had an issue yet after 2 years with the same rod ends with brass balls in them .........bob
bob1961 is offline   Reply With Quote
Old 03-24-2011, 07:51 PM   #5
Set of 8 Revo turn buckles and pushrods are $16 shipped on ebay and I get 4 strait links and 4 longer ones that I can bend to fit. Comes with all the rod ends and the length is good as well. JFYI.
Krakker is offline   Reply With Quote
Old 03-24-2011, 08:09 PM   #6
Originally Posted by dirk379 View Post
Yup that works.
http://www3.towerhobbies.com/cgi-bin...?&I=LXHFV9&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXHFV7&P=7
JeremyH is offline   Reply With Quote
Old 03-24-2011, 08:17 PM   #7
666
MODERHATER™
666's Avatar
10-32 threaded rod and 1/4 stainless tube work well for me.
666 is offline   Reply With Quote
Old 03-24-2011, 08:19 PM   #8
I've swapped some of my links for those, and all of my rod ends on my other links to the Traxxas ones.
GRIMGREG is offline   Reply With Quote
Old 03-24-2011, 08:25 PM   #9
In my area delrin rod can be sourced alot cheaper than stainless tubing. Although steel links look a lil cooler hehe so I'm thinkin of trying it next time
Meatwad is offline   Reply With Quote
Old 03-24-2011, 10:04 PM   #10
Thanks, links saved It's super easy to chop those down and rebraze the threaded portion on the end.
I haven't seen one of those rigs in quite some time. Must be a super cool rig
Old 03-25-2011, 07:32 AM   #11
I use Revo turnbuckles and pushrods as well but I had an extra set of Lunsford Titanium turnbuckles and rods so I used those. They are real light and extremely durable.
Airmaxx23 is offline   Reply With Quote
Old 03-25-2011, 07:54 AM   #12
Sorry...double post.
Old 03-25-2011, 08:02 AM   #13
i noticed nobody's mentioned my favorite way of mking links...cutting the shapes out of 1/4 delrin and just drilling ant tapping the ends
murderface is offline   Reply With Quote
Old 03-25-2011, 08:40 AM   #14
Thats the way I make links. Brake line, threaded rod, and rod ends.
country_crawler is offline   Reply With Quote
Old 03-25-2011, 12:10 PM   #15
I just tried out the threaded rod and brakline method last night. I busted out steering linkage and uppers and it worked out very well. It does add a little more weight but it is down low.
RksPlz is offline   Reply With Quote
Old 03-25-2011, 08:57 PM   #16
You can also get Traxxas Maxx links real cheap on eBay - best way to go IMLHO
entropy is offline   Reply With Quote
Old 03-26-2011, 12:41 AM   #17
I need to make some bent links and I keep thinking this would be the easiest way as well... but you need male threaded rod ends and I can't seem to find any for RC. Where do you get yours? Mine will be for my Losi Mini so I don't want to get to big.
Getrag is offline   Reply With Quote
Old 03-26-2011, 12:49 AM   #18
Why would you need male threaded rod ends? You could just make links using this method and then bend them or buy some aluminum tubing, bend it the tap and use long set screws to secure rod ends.. OR get some delrin rod (1/4", 5/16", 3/8"), drill and tap then heat and bend. No need for male rod ends at all.
Old 03-26-2011, 12:57 AM   #19
Damnit! your right. I wasn't even thinking of using a long set screw... I'm new to crawling so I haven't really seen much, all I have to go off are my own thoughts, I'll be honest I'm mad at myself for overlooking that though its a simple enough solution.
I'm gonna go make some tomorrow, thanks for the help!
Old 03-26-2011, 01:31 AM   #20
If you can't find long set screws another option is to cut sections of all-thread, that's how I made my delrin links. But I do recommend set screws as they are much easier to assemble.
