04-22-2006, 08:51 AM | #1 |
Rock Stacker Join Date: Nov 2005 Location: Street
| Swapped in real electronics...
and now when i get in the throttle a little bit to creep only the back tires spin but if i give it half to full throttle all tires spin. anyone had any encounters of this kind? -Don |
04-22-2006, 12:33 PM | #2 |
no one?
04-22-2006, 04:56 PM | #3 |
I wanna be Dave Join Date: Sep 2004
iho do you have the motors wired.
04-22-2006, 05:32 PM | #4 |
parallel
04-22-2006, 08:13 PM | #5 |
Rock Crawler Join Date: Dec 2005 Location: houston
Sounds like something in the front end is binding causing the motor to have to draw more power than the rear to get spinning. When you give it half throttle it's enough juice to overpower whatever is binding it up. Did it do this before you switched electronics?
04-22-2006, 08:21 PM | #6 |
not to my knowledge
04-22-2006, 08:44 PM | #7 |
just to make things clear, this is how you have it wired right? NOT LIKE THIS!!!! |
04-22-2006, 09:52 PM | #8 |
first picture, yes
04-22-2006, 10:30 PM | #9 |
mine does the same but at alot lesser extent and with the rear axle.im using a 18t esc. what esc you using ?
04-22-2006, 11:41 PM | #10 |
its a 15 turn IIRC
