05-10-2011, 12:39 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: fremont
| redrilling axial clockable cs
Hello! Has anyone drilled and tapped the set screw holes to 4mm? The aluminum must be pretty soft. I stripped a couple of the holes without any effort. Thank you for any input
05-10-2011, 01:11 PM | #2 |
Are you using just the set screw? Use button heads. edit: I just read this again...did you strip them while assembling or did they strip out from use? |
05-10-2011, 01:14 PM | #3 |
i used the set screws. I will get some buttonheads and go from there. What length should i get?
05-10-2011, 02:13 PM | #4 |
M3X8mm
05-11-2011, 01:43 AM | #5 |
I stripped them while assembling them. I called fastenal and found out they had an m3.5 tap. That would probably be better than trying to tap it at 4mm.
05-11-2011, 12:43 PM | #6 |
My last question is this: Would it cause any harm to just put two new holes on the top and bottom of the c?
05-11-2011, 08:07 PM | #7 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
I just drill them out to 3mm and the run the M3x8mm screw (button head) into the beef toobs. Casey Last edited by KC_JoNeS; 05-11-2011 at 08:41 PM. |
05-12-2011, 11:54 AM | #8 |
I'm going to go the beef toob direction. I can send gunnar the $ for the toobs?
05-12-2011, 01:30 PM | #9 |
Quarry Creeper Join Date: Aug 2010 Location: Sheboygan
You can get the toobs here. |
