05-12-2011, 08:52 PM | #1 |
RCC Addict Join Date: Oct 2007 Location: gervais
| Rubber Thingy lol
So I searched but didn't see or hear anything on the servo rubber things that go on the ears, how many of you use them and how many don't? I was debating on if I should leave them on or not alright it's a crappy pic but it's the rubber bushings that goes in between the screw and the servo ears Last edited by demonoid369; 05-12-2011 at 11:52 PM. |
05-13-2011, 08:48 AM | #2 |
I never use them. I will either use RCBros Servo Clamps or cone washers when using a larger servo.
05-13-2011, 08:59 AM | #3 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
Never
05-13-2011, 09:04 AM | #4 |
I haven't, but they're supposed to keep the ears from breaking off on a hard impact or something.
05-13-2011, 09:09 AM | #5 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
05-13-2011, 09:13 AM | #6 |
Thanks guys, I was thinking the same lines as to taking them off before but wasn't sure, now I'm going to lol
05-13-2011, 09:19 AM | #7 |
never used them, and even RTR's dont come with them.
05-13-2011, 10:44 AM | #8 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
I would assume these were mainly use in airplanes and helicopter, to reduce vibration during its flight. Cranking the screws down would lead to stripping, adding clamps or washers would also lead to extra weight which is a no-no in aircrafts. Just my 2 cents. BTW, I never use those rubber thingy as you decribed.
05-14-2011, 06:49 AM | #9 | |
I just use small steel flat washers under the screw head to spread the loads. The rubber grommets are vibration isolators, needed for other servo applications. In a crawler, there is really no vibration (other than dropping off a rock....) and the rubber adds some "give" which we DON'T want. | |
05-14-2011, 07:02 AM | #10 |
RCC Addict Join Date: Apr 2009 Location: United States of the Offended
There's supposed to be a brass bushing that goes through it after you put it on the servo ears, that way the screw tightens down on the bushing and not the servo ears. I don't use them since I got some RCBros clamps. |
05-14-2011, 07:03 AM | #11 |
I like to use them in most cases. It helps from breaking servo cases. I think in the last 6-7 years, I've only broke 2 servo cases, maybe three. More than likely, those broke when the "rubber thingy's" weren't being used. |
05-14-2011, 07:22 AM | #12 |
Ya I couldn't think of the name till I posted up the pic lol so it was called rubber Thingy, so far my last servo, which was a jr9100, I remember not using the bushings and it was fine, but tue 645 that I got in a deal awhile back did, so when I got my new servo I decided to ask and see what was up with them
05-14-2011, 09:58 AM | #13 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
Well what kind of servo did they come with? most dont come with them, Iv never used them, but If the servo was a cheapy servo and came with them, you may want to atleast use them, because the plastic could break just by tightingin the screws lol There is a reason..... |
05-14-2011, 10:16 AM | #14 | |
05-14-2011, 11:19 AM | #15 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
i have never bought a servo that didnt come with them, at least 4 different servo horns, screws to attach them, the collars to go through the "rubber thingys". they are deg designed for aircraft to help keep the high frequency vibes from killing the internals from the engines. but i also them in all my vehicles as well. they really help keep things from breaking. |
05-14-2011, 11:32 AM | #16 |
OK, I'll be the "butthead"........"Sounds like you & your other 1/2 have an issue, tell her it was cold & she doesn't need a 'rubber thingy', just wait until the room warms up..........." |
