05-22-2011, 08:03 AM | #1 |
Pebble Pounder Join Date: Jan 2009 Location: Bucktown
| strongest (heim) rod end????
hi i am looking for the strongest rod end 4mm or larger, for a large scale project (20 pounds). any advice would be nice thanks BIGGER IS BETTER |
05-22-2011, 12:27 PM | #2 |
Revo or Jato If you need bigger than that, search through McMaster. |
05-22-2011, 01:07 PM | #3 |
Rock Crawler Join Date: Nov 2009 Location: Southern, IN
Here's a couple... http://store.rc4wd.com/Steely-M5-Rod...int_p_650.html http://store.rc4wd.com/Steely-M4-Rod...int_p_649.html Last edited by Turn'Nburn; 05-28-2011 at 11:57 AM. |
05-22-2011, 01:32 PM | #4 |
Newbie Join Date: Jun 2008 Location: Barstow
Xtm has a shock end that is a good strong heim, way better that those sloppy rc4wd ones. Or like someone said, use McMaster-Carr. Sent from my DROIDX using Tapatalk |
05-22-2011, 03:04 PM | #5 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
Probably these, but not cheap: http://hirschmannusa.thomasnet.com/c...-duty-rod-ends |
05-22-2011, 07:23 PM | #6 |
thanks for the info, I am using revo ends now and they pop apart , my experence with cheap aluminom hiems is the race pops out , So im looking at the steel rc4wd 4mm hiems has any one had any luck with them BIGGER IS BETTER |
05-23-2011, 09:36 AM | #7 |
forget the junk that RC4WD sells, check out the steel ones that rc-channel sells, or go to the really good ones from McMaster-Carr.
05-23-2011, 09:48 AM | #8 |
Rock Crawler Join Date: Oct 2009 Location: home town marsing
looking for 4mm or bigger. I would start looking into 1/8 scale buggies. most of them are put together vary well most of the rod ends they use, are most of the time alot bigger than the revos. I would start their, then go to the other sites to see what you think would work better for ya. kinda show ya what I'm thinking of http://www.thefind.com/buy-aGydPnLN1...=ofna+rod+ends Last edited by spyderwebbcustoms; 05-23-2011 at 09:56 AM. |
05-23-2011, 10:11 AM | #9 |
Have you tried asking over at RCLargeScale.com? I bet someone there can help you |
05-23-2011, 10:29 AM | #10 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
I will agree with spyder. 1/8th rod ends can take serious punishment. Try looking for rear upper arm ends. Most of the latest kits use 5mm turnbuckles with 4mm balls. The best plastics are Mugen, Kyosho and Serpent.
05-23-2011, 11:12 AM | #11 |
Rock Crawler Join Date: Feb 2007 Location: CoMo...Kickin it with Holmes Hobbies
What about hpi 5B rod ends?
05-23-2011, 12:46 PM | #12 |
Quarry Creeper Join Date: May 2008 Location: Grande Prairie, Alberta, Canada
