07-17-2011, 09:34 PM | #21 | |
Rock Crawler Join Date: May 2011 Location: SoCal
And yes, I always use a long enough set screw that I can drive it all the way to the bottom of the hole for strength. Mcmaster has a nice supply of various length alloy steel set-screws both metric and SAE. I didn't check to see if the Losi hole is full depth, but no matter -- it can be. Last edited by WAM; 07-17-2011 at 09:39 PM. | |
07-17-2011, 09:40 PM | #22 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
Go back to my first post. I use a Dremel cutter bit to bore out the Losi ball to fit 3mm bolts.
07-17-2011, 10:16 PM | #23 |
Or you can just use the 4-40 screw. .006 difference will not matter (from 4-40 to 3mm), especially if the bolt is tight.
07-17-2011, 10:53 PM | #24 |
Yeah I think drilling it to 3mm or switching to 4-40 are both workable. Or if I really want to beef things up I could use the 4x4mm aluminum rod end and drill the chassis and axle to fit 4mm attach bolts. At a comp yesterday, I saw three rod end failures. Two were broken bodies and the third was a thread pull-out (wasn't deep enough). It's almost enough to want to give up on the plastic and accept aluminum's weight penalty. |
11-28-2012, 06:21 AM | #25 |
Quarry Creeper Join Date: Nov 2011 Location: Kentucky
| Re: Bent rod ends for triangulated links
One year later and Im in the same boat as the OP. Im looking at the RC4WD aluminum bent rod ends that are 4mm. Anyone have any input on these? I'm looking to run these with 4mm all thread and 1/4" titanium tubing if I can find it.
12-11-2012, 11:46 AM | #26 |
bumpin this for the reason posted above. Is the M4 about the same as the 8/32 that im using on the revo rod ends?
12-11-2012, 12:57 PM | #27 |
8-32 is .164" dia and M4 is .157". Both will work with a Revo r/e. But you originally asked about aluminum rod ends. Some say they wear out fast and my own experience is some seem to have a loose fit on the balls.
12-11-2012, 01:32 PM | #28 |
| Re: Bent rod ends for triangulated links The reason im asking about the M4 is, I don't wanna go down in strength. I wanna stay the same or have more. but by loose fit do you mean they pop out easy. I only wish that someone made a curved revo rod end or a curved jato rod end but that doesn't seem to be in existance right now. The purpose of these is to get a better grasp on a more precise link measurement after the cut. Im using (right now with revo rod ends) the 8/32 all thread and 1/4 stainless tube. When I bend the links neither side comes out the same due to the metal having the slight spring back effect. Plus is smashes the hell out of the tubing. So I was trying to find curved rod ends. Any sugguestions or info is greatly appreciated at this point. The rod ends are the more budget friendly option to buying a small bender and all new solid stock and cutting the threads since I don't have a lathe. So Im up and open for anything.
