06-21-2011, 01:09 AM | #1 |
| 2 Different MOA Axles Question
Did the search, I got lost . If it's a repost, sorry. So here it goes: Could you run a XR10 axle and a Berg axle on the same rig? Front Rear/ Rear Front? Which axle setup would make more sense? Or even ESC setup, duel/single? Damn I should call this a can-o-worms thread... Thanks in advance. |
06-21-2011, 01:15 AM | #2 |
RCC Addict Join Date: Nov 2004 Location: union
I've put some thought into running a Berg axle in front and a xr in the rear. You would have a forward weight bias and the motors could be wired in the same direction.
06-21-2011, 01:58 AM | #3 |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
does anyone know the gear ratio on each of these axles? are they close? or could they be tuned to be?
06-21-2011, 02:00 AM | #4 |
06-21-2011, 02:08 AM | #5 |
I am sure it could be geared out or just run a dual esc setup.
06-21-2011, 07:51 AM | #6 |
Well, I would think that you would want the XR front axle to take advantage of the steering. However, the berg rear would weigh more and throw off your bias. What exactly are you trying to accomplish? |
