05-08-2006, 12:30 AM | #1 |
RCC Addict Join Date: Oct 2005 Location: $t. Helen$, OR
| Shocks and stop links and anything in stock general
I was wondering if anyone cuts out the stop links, and if so why or why not?? Also what do the limiting straps help, or is that just a cool thing to do? anything else about shocks you all can give me a heads up on Thanks I am searching for anything and everything usefull, but manly cant find anything on those questions Relocation for the rear and maybe front shocks? |
05-08-2006, 01:10 AM | #2 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
by stop links, do you mean the things that stick out of the chassis that keep the links form going down? if so, do not remove them, the axles will pull themselves under the crawler and pull the shocks apart. limit straps help if yo are having problems with the shocks pulling apart. make them just long enough to allow the shocks to ALMOST pull apart......i haven't needed them yet.....i might need them on the new chassis though, haven't even installed shocks on it yet..... i moved the upper mounts of my rear shocks in about an inch on each side and it helped a lot with flex. also, look under the blue blocks on the axles and you will see some little pivot stops, carefully drill them out and you will gain flex. |
05-08-2006, 01:27 AM | #3 |
Cool thanks I have been searching for some time now and have only found a one person that cut the stops off, and yes you understood what i was talking about by stops Thanks again... will be relocating shocks and limiting straps next, flex is good |
05-08-2006, 09:09 AM | #4 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
The only reason to cut off the stops on the chassis would be to do a tummy tuck that much farther. You'l gain prolly another 1/2"+ of ground clearence but you'll have to use limiting straps to limit the axle travel to the same place the stock limiters would have been. So all in all, cut them if you want the extra ground clearnce but not for more flex (cause your not going to get anymore than before).
05-08-2006, 10:28 PM | #5 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
| 90
I got almost 90 with out removing the stops. you do have o move the shocks and lower ,and move the axels tho
05-08-2006, 10:53 PM | #6 |
90* of artic is good for nothing but poser shots
05-08-2006, 11:15 PM | #7 | |
Ummm pix?:? | |
05-09-2006, 08:44 AM | #8 | |
05-09-2006, 12:01 PM | #9 | |
05-09-2006, 07:46 PM | #10 |
Newbie Join Date: Apr 2006 Location: Morgantown,WV
that's the idea! Nice KTM BTW. I ride a '01 YZ250 done in white. http://www.rcuniverse.com/community/...y&memid=228664 its in there somewhere... |
05-09-2006, 08:11 PM | #11 | |
Thanks, I love my bike, jeep, computers, and well anything else with a engine or motor. And back at ya nice bike, nice hobbies, I love them too, what keeps me going | |
05-09-2006, 11:52 PM | #12 |
so now that I have limiting straps I am going to cut off the stops??? Good idea:? Oh ya I relocated and limit straped the front, I got bored and can not sleep... nothing new :neutral:... Check my build page in a min. I will have pix up |
05-09-2006, 11:58 PM | #13 |
dont cut the stops off the chassis......its pointless have you removed the stops from the axles? |
05-10-2006, 12:00 AM | #14 | |
and nope have not, can you point them out, are there pix I missed in a sticky I will research one way or another, BUT OMG so much flex now | |
05-10-2006, 12:03 AM | #15 |
05-10-2006, 12:08 AM | #16 | |
05-10-2006, 02:38 PM | #17 |
Yeah, don't cut the tabs off the chassis! It's a bad idea in every way except for a higher tt, which I don't think your doing, so just leave them on there.
05-10-2006, 03:10 PM | #18 | |
Roger roger | |
05-11-2006, 06:00 AM | #19 |
Quarry Creeper Join Date: Apr 2006 Location: winchester
everyone savage shocks are longer than nylint shocks, oiled and have a better spring rate than stock
05-11-2006, 08:16 AM | #20 | |
I will run them if you pay, want my address? | |
