07-24-2011, 11:22 AM | #1 |
| Most durable Axial transmission outputs?
Hello all, like the title says, I am looking for the most durable outputs for the Axial transmission, that are readily available I have broken 2 of the Robinson Racing lockers now so I need something better, I have some old CDW ones, would like it if Nova made more of his, but I need something now! Please inform me?! |
07-24-2011, 12:00 PM | #2 |
RCC Addict Join Date: Jun 2005 Location: Prosser
Not as beefy as what you are speaking of, but very tough...have yet to break one! http://www.rpphobby.com/product_p/ax30544.htm Edit: Gave you an out of stock item |
07-24-2011, 12:02 PM | #3 | |
Yea, I'm going to give those a try. Hope they work. | |
07-24-2011, 12:03 PM | #4 |
| Running on my "Honcho with a 7T Puller on 3s, and 13.5" wb with ripsaws, I can beat the stink out of it, and never failed...
07-24-2011, 12:06 PM | #5 |
RCC Addict Join Date: May 2008 Location: Green Bay
What about these? http://supershafty.com/8mm.html May take some work for the drive shafts, but these are BEEFY |
07-24-2011, 12:20 PM | #6 |
07-24-2011, 02:35 PM | #7 |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
I have run the previous mentioned steel Axials and also run this on one of mine. Never a problem with either: http://www.hot-racing.com/index.cgi?...=SSCP38X;c=456 I know some people knock on HR stuff. But I have never had a bad part from them. I have used many parts from them on many different rigs, never a fit or finish problem ever. They are local too (about an hour away). At least their main distributor is anyway, not sure where they are made. |
07-24-2011, 03:56 PM | #8 |
Rock Crawler Join Date: Jan 2006 Location: coventry, ct
im looking for a quality 1 pc diff locker too. i keep shearing off the 3 screws on either side that hold them to the gear.
07-24-2011, 07:08 PM | #9 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
07-24-2011, 08:27 PM | #10 | |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
07-24-2011, 08:31 PM | #11 |
RCC Addict Join Date: Nov 2008 Location: Santa Fe, NM
I run this in all my rigs http://www.rpphobby.com/product_p/rrp1542.htm |
07-24-2011, 08:44 PM | #12 |
RCC Addict Join Date: Jul 2006 Location: Pasadena
He said he ran through 3 of them.
07-25-2011, 01:24 PM | #13 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
Patrick, you need to learn to drive smoother.....I never broke one of those in the two years I owned it. Maybe if you quit driving through the campfire you would stop taking the temper out of the output . Last edited by War Pig; 07-25-2011 at 01:27 PM. |
07-25-2011, 01:46 PM | #14 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
I have been using the steel bowie ones for quite sometime. I found that better bearings and going with a metal case in higher than normal speed where tons of torque is added helps eliminate any extra slop Oh yeah and if your gonna drive the truck like a demon through campfires, get an e- revo |
07-25-2011, 01:57 PM | #15 | |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
WOW ! ! ! REALLY ? Two of these ? REALLY ? ? ? | |
07-26-2011, 07:36 AM | #16 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
Where are you breaking them?
07-26-2011, 11:27 AM | #17 |
Rock Crawler Join Date: Jun 2007 Location: Arlington
I've broken one of the Robinsons. They shear off the outputs with the right amount of power. 4S and a 35T Holmes Pro will did it for me. I can get about 15 minutes out of the aluminum Axials if I'm lucky. I'm waiting on the steel ones to come back into stock since I can't afford the CI ones. |
07-27-2011, 09:30 AM | #18 |
I have the solid steel ones in two of mine and haven't broken them. I've snapped a couple of the stock style bolt on ones, but I'm impressed if you're breaking the solid ones.
08-28-2011, 01:26 PM | #19 | ||
Really, I think they use cheap alloy or something, really brittle. The outputs shear right off. I have some real high quality machined ones in now that are holding up nicely. | ||
08-28-2011, 01:28 PM | #20 |
I joined the Band! Join Date: Jun 2008 Location: Sacramento
was it during a punt into the field goal ? |
