05-10-2006, 11:23 PM | #1 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
| power switch problem
i searched and didn't find an answer for this..... anyone know how to bypass the main power switch? mine has a short in it and will make the truck stop and if i wiggle the switch it starts working again..... |
05-10-2006, 11:32 PM | #2 | |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
05-10-2006, 11:37 PM | #3 |
ok thanks!
05-11-2006, 05:17 AM | #4 |
Quarry Creeper Join Date: Apr 2006 Location: winchester
toggle switch would be sweet you could get one form pep boys that lights up |
05-11-2006, 02:54 PM | #5 |
wait, which wires do i connect together to bypass it? red- big black and green-little black? or do i just connect all of them together? |
05-11-2006, 03:00 PM | #6 |
what purpose do the green and little black wire serve? i just used my test light to see which wires had power before and after the switch is flipped and only the big black wire has power before its flipped and only the big black and red have power after its flipped.... |
05-13-2006, 04:57 AM | #7 |
havnt played with that part of the wiring but you should now that you have every thing apart. connect the battery and see what has to be connected to get the thing to work! i would recomend usin a toggle switch still though:?
05-13-2006, 01:26 PM | #8 |
i checked with a test light and am the only 2 wires that ever get power are the big ones, the little ons never see power......
05-13-2006, 08:43 PM | #9 |
Quarry Creeper Join Date: Jan 2006 Location: PNW
my switch crapped out on me. The other 2 wires I just capped off, and I just have 2 way toggle switch with the larger red and black wires.
05-13-2006, 09:20 PM | #10 |
wow CHUKI, i thought you were dead or something! aint seen you on in a while thanks for the info! |
05-13-2006, 10:12 PM | #11 |
Have you check the wiring to it yet. Mine was just a little loose and that was causing my problem.
05-13-2006, 10:19 PM | #12 |
no, i haven't.....i dont have any need for it, so i am just going to bypass it and disconnect the battery when i am done playing with it.....
05-13-2006, 10:20 PM | #13 |
That works too.
05-13-2006, 10:22 PM | #14 |
i sure hope so because its not exactly fun when your halfway up a climb and the thing shuts off and you have to go tap on the power switch!
05-13-2006, 10:24 PM | #15 |
I could see how that would zap all the fun. Hope it works for you.
