05-18-2006, 06:23 PM | #1 |
Newbie Join Date: May 2006 Location: CHAPMANSBORO
| Adding Weight
I'M GOING TO PUT SOME WEIGHT IN THE FRONT END OF MY JEEP.HOW MUCH IS RECOMMENDED????? USING STICK ON TIRE WEGHTS
05-19-2006, 08:04 AM | #2 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
I use about 750 bb's in each front tire. I think that's about perfect. I've tried more and less and 750 seems to work great. If you can figure out how much a bb weights then you could convert that to a total oz measurement and do that much in tire weights.
05-19-2006, 11:45 AM | #3 |
Rock Crawler Join Date: May 2006 Location: Burrillville, RI
so is it best to only put some weight in the front tires? I've read the other posts on this... so I guess a more specific question would be . Is it a good idea to start only adding in the front for a noob? Scott |
05-20-2006, 06:41 AM | #4 |
Newbie Join Date: May 2006 Location: crawlberland MD
i was crawling one cay and couldnt get over a hill with out rolling over back wards so i put a rock in between the body and the chassis and i went right over it.
05-20-2006, 06:50 AM | #5 |
Don't U Here The Bb's Rolling Around In The Tires?i Was Just Gonna Stick The Tire Weights Under The Front Part Of The Body,like Under The Hood!i Was Just Tryin To Figure Out How Many Oz's I Should Use.
05-20-2006, 04:10 PM | #6 |
Rock Crawler Join Date: Mar 2006 Location: Dayton
| try a pound and if it's too much, take away as needed -Dalton |
05-20-2006, 05:54 PM | #7 | |
05-20-2006, 06:02 PM | #8 |
Any Idea How Many Oz's???
05-20-2006, 06:55 PM | #9 |
a pound is 16 ounces i think...don't quote me on that though cause im not sure -Dalton |
05-21-2006, 10:40 PM | #10 | |
Newbie Join Date: Jan 2006 Location: Hillsboro
05-22-2006, 11:29 PM | #11 |
Quarry Creeper Join Date: Jan 2006 Location: knoxville
i wanted to get stick on weights like that to put in the tires and it really doesnt matter where u put the weight on the axle, it will be on the axle so it will be the same on the steering, the more weight u add on the crappier the steering will be, i think im gonna just stretch mine out a hole for better weigth distribution |
05-23-2006, 07:42 AM | #12 | |
