05-22-2006, 06:00 AM | #1 |
| So i drove the nylint 1/6...
Yesterday i had my battery all charged up , after an 18 hour wait , but finally went for my first rock crawl, i must say i was impressed, it has a lot of torque( i first was pulling my kid around in his little tikes wagon, he is 20 months old weigh 25lbs. + the wagon another 6-7 lbs, pulled them no problem in hi gear ) i took it out to a construction site, a lot of cinder blocks and other building materials in mount shape , and it took them all like a champ, maybe once or twice it got hung up in it's center or a diff, but that will get resolved soon, only thing i'am worried is the transmission/driveshafts not holding up, it sounds aweful when i switch from lo to hi and viceversa, any comments on how to improve these parts will be greatly appreciated, i know search, i'am not so good with it i've tried help and sorry for the long rant |
05-22-2006, 07:00 AM | #2 |
Quarry Creeper Join Date: Dec 2005 Location: Southern Maryland
That sound is normal, it wpnt effect the performance of the truck but you do want to check out the belts if you do some mudding or stream running. but welcome to the hobby cartronic.
05-22-2006, 07:47 AM | #3 |
Quarry Creeper Join Date: Jan 2006 Location: Reno
don't run it from high straight to low, let the car stop first, then switch, i go a bit reverse to set the gears, seems to work better
05-22-2006, 07:53 AM | #4 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
That noise is normal. The Selector levor is spring loaded so it bounces off a gear making all of the noise after it's in the right position but the gear is still rotating, nothing to worry about.
05-22-2006, 07:55 AM | #5 |
thanks for the welcome joe, bknight, thanks for the tip, also do you guys know if the belts on e-bay are worth it, i mean are they better than stock.
05-22-2006, 08:08 AM | #6 |
NO!!!!! Don't buy the belts on ebay! Go and buy a 1 13/16" o-ring from Checkers and put that on the front and then take the stock front belt and put it on the rear, perfect fit. Only cost ya like 50 cents. I'm not sure exactly what the belts on ebay are but the o-ring works amazing and it's a heck of a lot cheaper.
05-22-2006, 08:25 PM | #7 | |
RCC Addict Join Date: Dec 2005 Location: Beaver Falls
05-22-2006, 09:21 PM | #8 |
Newbie Join Date: Dec 2005 Location: Salem
Same as Schucks or Kragen. Auto parts stores.
05-22-2006, 10:12 PM | #9 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
yeah Shucks Kragen Checkers are all the same, good luck, and hope your son drives it soon enough!! |
05-23-2006, 01:03 AM | #10 |
Newbie Join Date: Apr 2006 Location: union city
| o-ring q.
wrecker, is there difference in size between the front and rear o-rings?
05-23-2006, 05:23 AM | #11 | |
05-23-2006, 02:43 PM | #12 | |
Newbie Join Date: May 2006 Location: banner elk
05-23-2006, 03:58 PM | #13 | |
05-24-2006, 10:55 PM | #14 |
Pebble Pounder Join Date: Apr 2006 Location: Jackson
I got new orings from Napa, 2 of each size the guy gave them to me free. I replaced both front and rear belts, worked somuch better untill we stripped one of the planetarys:-( |
05-25-2006, 12:39 PM | #15 |
survey says....? let them slip, instead of killing your gears? or are replacement gears easy to find |
