Thread: Diff gearing?
Old 10-05-2011, 10:42 AM   #1
Default Diff gearing?
Of all the builds I've seen with the front being the slash 4x4 IFS and solid rear axial axle, I don't ever remember reading about the diff gears? Are they the same on the axial and slash or would you need to buy either a over drive or under drive gear for the axial?
demonoid369 is offline   Reply With Quote
Old 10-05-2011, 01:06 PM   #2
Proverbial threadkiller
Trubble's Avatar
Tower Hobbies lists the ring & pinion for the Slash 4x4 at 37/13, and the AX-10 at 38/13, so just using the "stock" ratios, the rear would be slightly underdriven (or the front would be overdriven). Can't find any evidence of a 37 tooth pinion for the Axial axle, didn't look for a 38 for the Traxxas axle.
Trubble is offline   Reply With Quote
Old 10-05-2011, 05:34 PM   #3
Alright so is everyone that's has a IFS rig running normal gears or is there a trick to it?
Old 10-05-2011, 06:26 PM   #4
the axle ratios are a bit off but not enough to really worry about unless its going to be driven on high traction flat surfaces alot.
benoj is offline   Reply With Quote
Old 10-05-2011, 06:58 PM   #5
Could you change the pinion to make it equal the same? I know one tooth difference won't do much but if there is a way to make it geared ish the same, it would be cool
