10-05-2011, 10:42 AM | #1 |
RCC Addict Join Date: Oct 2007 Location: gervais
| Diff gearing?
Of all the builds I've seen with the front being the slash 4x4 IFS and solid rear axial axle, I don't ever remember reading about the diff gears? Are they the same on the axial and slash or would you need to buy either a over drive or under drive gear for the axial?
10-05-2011, 01:06 PM | #2 |
Tower Hobbies lists the ring & pinion for the Slash 4x4 at 37/13, and the AX-10 at 38/13, so just using the "stock" ratios, the rear would be slightly underdriven (or the front would be overdriven). Can't find any evidence of a 37 tooth pinion for the Axial axle, didn't look for a 38 for the Traxxas axle.
10-05-2011, 05:34 PM | #3 |
Alright so is everyone that's has a IFS rig running normal gears or is there a trick to it?
10-05-2011, 06:26 PM | #4 |
the axle ratios are a bit off but not enough to really worry about unless its going to be driven on high traction flat surfaces alot.
10-05-2011, 06:58 PM | #5 |
Could you change the pinion to make it equal the same? I know one tooth difference won't do much but if there is a way to make it geared ish the same, it would be cool
