10-10-2011, 09:26 AM | #1 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shock Oil Information
I had been having trouble finding the right shock oil for my super (was running Losi 100wt, but needed something heavier) and in my search, I came across some information that I thought others might find quite useful. I did not know that there were differences in the classification of shock oil weight between different manufacturers. Some manufacturers (for example, Losi, Associated and Traxxas) use a numerical system of "weight values" to represent the different viscosity levels of their oils. This threw me off when I asked the LHS about heavier oil and he suggested diff oil of 1500. In my mind, that was 15 times heavier than what I had in there, but, as the guy at the LHS explained, that isnt so. He explained to me that the Losi 100wt oil is about 900 CTS. Now it started to make sense! I searched around on the internet and found some useful information so I thought I would post this here for others that might be as confused as I was. This website also gives information about how the shock oil changes with ambient temperature. Silicone shock and differential oil and more In the beginning of the 80's cars were equipped with small shock absorbers 1/4 of the current size. The shock fluid used was normally a kind of transmission oil. These oils always changed in viscosity (thickness) during use and temperature and a stable shock oil was not there. Therefore all kinds of products were tried. Even STP oil was used, you then had to warm up your shocks before racing with a hair dryer before you could use them. Fortunenatly silicone oil was introduced in the mid 80's. This type of oil has an better constant viscosity over a wider temperature range then other fluids but still is not complete temperature stable! The thickness of the oil is officially rated in Centi Stokes "Cts". Centi Poise (nowadays called Pascal per second) is the result of the Centistokes value magnified with the density of the oil. Normally for silicone oil this value is 0.9875 = almost 1.0 An other known and used American rating is WEIGHT "WT". This WT or W rating is a non world standard and is introduced by Associated and not comparable between brands using this W or WT rating. Thanks to Casper who found this remark on the net about SAE WT: "Correct measures of viscosity are centi-stokes, N/m^2, or poises, depending on how you define it. SAE WT is not really a measure of viscosity. The SAE scale was designed for classifying motor oils. For example SAE 30/40 means that the viscoity is one value (30) at one temperature and an equivalent (40) at the engine running temperature. When the number has WT after it this means "winter" so that the oil will have a particular value at I think 0 degrees Celsius. The main problem with using the SAE scale oil is that each SAE band can encompass a large variation in viscosity. For example one manufacturers SAE 5 can be anothers SAE 10 and both are within limits. Using the SAE scale oil is best only to compare one manufacturer. " Concerning Cts the thinner the oil (fluid) the lower the number, the ticker the oil the higher the number. For normal shock absorber use, this rate may vary between 100 Cts until 900 Cts. Nowadays we use O-ring sealed diffs, so we can use silicone oil in the diffs instead of thick grease. For diffs the rate may vary between 1.000 Cts (loose) up to even 500.000 Cts (very, very, stiff). Some USA based companies still are using the "WT" weight rating, where Japanese and European companies use the better linear industry standard Centi Stokes or Centi Poise rating. A lot off people think that the ratings between the "WT" and "Cts/Cps" ratings are linear but this isn't the case. If there is a factory that can provide oil for testing we can arrange this to see if the product reaches the specification claimed or convert to Cts! Which manufacturer use which rating? Which manufacturers you can use same rating oil? Only manufacturers using Cts as rating are using a world standard and can be mixed used. Other ratings like W and WT differ from brand from brand as WT or W is not a world standard!
Last edited by JeremyH; 10-10-2011 at 09:35 AM. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
10-10-2011, 09:28 AM | #2 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
If you have better information let us know For shock absorber use, this is the comparison table when using LOSI, ASSOCIATED and SERPENT some others silicone oil rated in "WT" "W" or are not labeled with a rating but just a number like 30/300
The 50 Cts steps between "Cts" rating are linear, where the 5 "WT" steps used in the "WT" rating are progressive compared to the real thickness of the oil. No one can tell TEAM TWF8 how "WT" OR "W" rating is measured!!!!! If you know it let us know! info@twf8.ws | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
10-10-2011, 09:28 AM | #3 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
We tested this oil supplied by Serpent Benelux on 04-01-2005 in our labaratory and compared them with a calibration oil.of 100 Cts. Conclusion: Serpent oil is way of linear with Cts rating
10-10-2011, 09:29 AM | #4 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Use the values above for your benefit and as a guideline.
Use the values above for your benefit and as a guideline. * The value 15 Weights we measured was like water thickness and is probably a filling fault at the factory. Altough the contents was silicone oil it was to thin for the 15 WT specs and can not be used for the shocks. Associated oils were provided by Kendall Bennet from A-mainhobbies and Tony Penzincka from Tony Screws *T he cyan colored values collum are provided by Kurt Menger from Team Assosiated R&D and are the values that will be curerntly mentioned on the bottles to give comparising with Cts values. (18-10-2007)
Use the values above for your benefit and as a guideline. Trinity oils were provided by Kendall Bennet from A-mainhobbies and Tony Penzincka from Tony Screws | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
10-10-2011, 09:30 AM | #5 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Use the values above for your benefit and as a guideline. Losi oils were provided byVolker Gerdes from BUGGY-SPORT.INFO Currently we are measuring our oils with a RHEOMETER. A sample of such a machine can be found here This device is able to measure more accurat regardless the viscosity. From September 2006 we measure all oils with a RHEOMETER. SILICONE SHOCK OIL AND TEMPERATURE Although everybody thinks silicone oil is not affected by temperature, we can wake you up out of that dream. When the same test is done @ 10 or @ 30 degrees Celsius we get other values! Test result from our laboratory provid us with the following fist rule: Below some examples.
To estimate your needed viscosity we made a XLS spreadsheet which you can use for calculating the correct viscosity. You can download it here. Team TWF8 special thanks goes to Jacco Koch our Chemicals specialist from The Netherlands for testing the fluids and the pictures. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
10-10-2011, 09:31 AM | #6 |
Sorry for the multiple posts, but there were a LOT of characters on the original page and it wouldnt let me put them all in one post. Anyway, I hope this helps some folks out.... |
10-10-2011, 09:53 AM | #7 |
RCC Addict Join Date: Jan 2005 Location: Germany north
10-10-2011, 04:46 PM | #8 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I would say if you need that thick of oil, there are other issues. I say toss those red shocks in an envelope and I will trade you for a set of plastic traxxas shocks that do not even need oil. I will even throw in a $5 to cover shipping your to me.
10-10-2011, 04:57 PM | #9 |
Haha! I tried some 1500 cts as well as some soft internal springs (along with my external springs) and it is getting there. I plan to try some medium internal springs in the front and hopefully that will do the trick.
10-10-2011, 05:06 PM | #10 |
Different shock pistons? Always worked for me.
10-10-2011, 05:09 PM | #11 |
I would recommend a sticky on this thread. I use the same link Egressor for tuning my touring car but having all this in front of ya can really help dial a rig in. Great post Jeremey, thanks for taking the time. |
10-10-2011, 05:29 PM | #12 |
| My super is quite heavy...the leverage on the front end is ridiculous and these 1/10th scale shocks and springs just aren't up to the task. I am currently using 2 hole pistons. I did nothing but copy and paste so that the folks using the search function on this forum can find it easier. The real work was done by the folks who wrote the article. |
10-10-2011, 05:36 PM | #13 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Thanks for finding the info Jeremy. I always knew that there was variance between different companies. Now i realise how big that is...Hmmm....Sticking to one brand more often now.
10-10-2011, 05:36 PM | #14 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
| Im not 100% positive but I believe I have Mugan 700wt in my shocks on the teenycar. War Pig seems pretty knowledgable about that stuff. |
10-10-2011, 05:56 PM | #15 |
10-10-2011, 06:30 PM | #16 |
10-15-2011, 03:53 PM | #17 |
Rock Crawler Join Date: Jul 2011 Location: Incirlik AB, Turkey
So the lower the number the softer the oil? How's the softer; harder affect the shock travel? Harder oil rebounds quicker, better for high speed?
10-15-2011, 04:02 PM | #18 |
Higher number means the fluid passes more slowly through the pistons.
10-21-2011, 06:17 AM | #19 |
Rock Crawler Join Date: Oct 2009 Location: Brussels
Here's everything in one chart Hope this help someone. |
10-21-2011, 09:29 AM | #20 |
