10-21-2011, 03:44 PM | #1 |
Quarry Creeper Join Date: Aug 2008 Location: Salford, UK
| torsion mounting
I want a torsion fixing and i am going to use some piano wire/spring steel. Now normally you would fix a plate to the top of the axle and trap it in there, however because of my 'upside down' design i cannot. I need the fixing point to be right in the middle(horitontally) of the axle, what would be the best way of mounting it? Craig |
10-22-2011, 07:40 AM | #2 |
RCC Addict Join Date: Nov 2005 Location: Kansas
On what axles? TLT or Axial I assume? you could drill and mount a block to the top of the servo plate, and run the wire through that... A little more insight as to what you're trying to acheive might help as well |
10-22-2011, 08:00 AM | #3 | |
Its WK axles. I am making a sort of random collaboration of a speedy rock racer / foff but one that can drive upside down to - Like the old tamiya rebound. Craig | |
