11-05-2011, 07:16 PM | #1 |
Quarry Creeper Join Date: Feb 2010 Location: Knee deep in a creek with a fish on the line
| Bearing size
I am working on a project to put axial c-hubs and knuckles on some trex axles. The inside of the axial knuckles have a bearing seat for a 5x15x4 bearing. Trouble is I cannot find that bearing on avid, or Boca bearings website. I have a 10x15, and 5x10 together that seem to work. Any one know Where i can get those bearings, or do people just run the 2 bearing combo. Thanks for the help |
11-05-2011, 07:51 PM | #2 |
Rock Crawler Join Date: Oct 2011 Location: south of nowhere
Tower hobbies has them from Thunder Tiger, I've run them in two crawlers for some time with no problems and there cheaper than axial. |
11-05-2011, 09:19 PM | #3 |
I've been having great luck with the bearings I buy from 'team fast eddie'.
11-05-2011, 09:48 PM | #4 |
My bad I guess. what I need is a link to a 5x15x4 bearing. It is the inner bearing for the axial ax-10 knuckle
11-05-2011, 10:46 PM | #5 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
The inner knuckle bearing for a AX10 is 10x15x4mm (part#: AXA1230), the outer bearing is 5x11x4 (AXA1221). So i'm not sure why you're looking for a 5x15 unless you're wanting to run only the stub axle into the steering knuckle rather than the top of the dog bone cup like the stock AX10 axle has. But looking at my local bearing place (smallparts.com.au) i only found one close and that's 5x15x5. Here's a link to it: MR1552RSC613 Small Mechanical Parts and Components Last edited by WIDELOAD; 11-05-2011 at 10:50 PM. |
11-06-2011, 05:39 AM | #6 | |
11-06-2011, 03:53 PM | #7 |
No worries, that explains it...Found a part number through BOCA for you. Still 5x15x5 though, haven't found any that are 4mm thick yet. Boca Bearing Company :: Ceramic Bearing Specialists Last edited by WIDELOAD; 11-07-2011 at 12:18 AM. |
11-06-2011, 04:55 PM | #8 |
holy 21.00 batman think I will stick with my double bearing at 2.00. |
