06-05-2006, 10:34 AM | #1 |
Rock Crawler Join Date: May 2006 Location: Burrillville, RI
| tension on o-rings
how do I determine how tight I make the belt for the drive? I will be mounting my outboarded motor tonight and do not want to make it too tight/loose ... is there a general rule to this or just kinda go by feel? Scott |
06-05-2006, 10:39 AM | #2 |
RCC Addict Join Date: Jul 2005 Location: Provo
tight |
06-05-2006, 10:43 AM | #3 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
to tight will cause you to eat the planetarys when your bound up, the weak link is the belt system and it will slip...if you get the belt to tight, it cannot slip and the weak link will become soemthing else....most likely the couplers, but some people have munched the planetarys after putting in a belt that was to tight |
06-05-2006, 10:54 AM | #4 |
Quarry Creeper Join Date: Apr 2006 Location: winchester
i used an extra steering belt for the rear end of my crawler it has alot of tension but its perfect; no slipping at all now on those crucial hill climbs. you can see pics of the crucially modded crawler here looke pics :-P |
06-05-2006, 10:56 AM | #5 |
i used the front belt from my stocker in the rear of my modded rig for the time being, but since my modded rig is dead, i guess i will put it back in the stocker so i can play with it......
06-05-2006, 11:04 AM | #6 |
I guess ill just wing it......heh.... not too loose, not too tight
06-05-2006, 12:15 PM | #7 |
Quarry Creeper Join Date: Jan 2006 Location: knoxville
i used a little shorter o-ring than the stock front belt for the motor relocation and its not extemely tight, u should be abe to move it back n forth while its on the pulley's about a 1/2 in. to feel the tension and u shouldnt have to use muscle to do this (just do it easy, u dont have to try n rip it off the pulley's
06-05-2006, 12:17 PM | #8 |
hmmmm......i used the fornt belt and its actually to tight for comfort for me....
06-05-2006, 12:23 PM | #9 |
it depends on where the motor is sittin, mine is close to the front as i could get it and i tried to use the front belt but it was a tad too loose thought it would have proly worked but i wanted a lil more tightness
06-05-2006, 12:38 PM | #10 |
I think I have enough information.... I will try to take some pics while I am doing it.... the only thing im not 100%on is the locking of low.... but I think I just need to look at the axle to understand where to hot glue it
