06-05-2006, 07:19 PM | #1 |
Pebble Pounder Join Date: Jul 2005 Location: Greece
| Calculating gear ratios
I am in the process of building a custom transmission. I know the ratio of the first to gears and the second two. How do I calculate the ration when these two sets of gears are combined? Am I correct that I just add the ratios of all the sets of gears and that is the final output? Finally what is the gear ration of the pede tranny so that I can compare.
06-05-2006, 07:44 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
The pede tranny is 2.72:1
06-05-2006, 10:27 PM | #3 | |
Rock Stacker Join Date: Aug 2005 Location: It's hot
On a side note, how many gears are you using? Do you have any pictures? I've been building quite a few transmissions lately...but frustration has finally set in (Dremel crapped out this morning) | |
06-06-2006, 03:45 PM | #4 | |
06-06-2006, 05:00 PM | #5 |
A 90 tooth spur is huge, the radius on it would either set your driveshafts really high in the chassis, or the spur would be hanging way underneath. When I built my MKI transmission (and the MKII re-work) I used several small gearsets to get the required reduction, with the final gear on the output shaft having a very small radius, allowing for better driveshaft angles, without sacrificing ground clearance |
06-06-2006, 07:30 PM | #6 | |
06-07-2006, 01:03 AM | #7 |
Running a transfercase in addition to the transmission might raise the center of gravity quite a bit. I countered that by positioning my small motor at the very bottom, against the skid, then positioning the gears so that the reduction followed the path of an upside-down U. I've pulled all of my gears out of radioshack trucks. So far, those gears are tougher than a TLT pinion's shaft, and they have small diameters too. You might want to consider buying 2 or so cheap RS trucks, just to pillage the gears and motors out of them. Doing that, you can create virtually any ratio you would need, it would all fit in a small area, and it's cheap. |
