06-10-2006, 01:20 PM | #1 |
Rock Crawler Join Date: May 2005 Location: Minnesota
| o-ring replacements!
hey guys, i now to replace the front belt use a 1 7/8 o-ring but hoiw about the rear? wat size fits that? i would go find out but i alreaddy cut both of mine! |
06-10-2006, 01:47 PM | #2 |
Rock Crawler Join Date: May 2006 Location: Burrillville, RI
did you outboard your rear motor? If so it could depend on where/how you mounted it....if you buy a 1 5/8 , 1 3/4 , 1 7/8, and a 2 inch. I can almost guarantee you will have one that fits properly... and it will caost you under 2 bucks
06-10-2006, 02:28 PM | #3 |
RCC Addict Join Date: Oct 2005 Location: $t. Helen$, OR
I am running both front and rear on 1-7/8ths The rear I remounted the motor and it works great the front is stock and it helped a lot, my stock front belt stopped pulling the front tires, now it burns them off |
06-10-2006, 04:22 PM | #4 |
so far my motors are still mounted in stock location! so would it still be 1 7/8 for both?
06-10-2006, 05:37 PM | #5 | |
and if that doesnt work go with 1-13/16th good luck and i am sure u will be happy when it is all over | |
06-10-2006, 10:49 PM | #6 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
1-13/16" in front and the stock front belt out back. Done it on like five of them now and it works great! Or put a 2" out back.
06-11-2006, 08:50 AM | #7 |
Pebble Pounder Join Date: May 2006 Location: Southbury
Yeah, I think the rear requires a bigger replacement belt than the front to prevent too much stress on the parts. I put the stock front belt on the rear and put 1-7/8ths on the front. Works great.
06-12-2006, 04:16 PM | #8 |
Newbie Join Date: Mar 2006 Location: Monticello
1-13/16 is a little too tight in the front, i just stripped the low gears out completely in mine after putting the o-ring in, it only took a split second of binding, go with a 1-7-8
06-12-2006, 06:06 PM | #9 |
I'm running 1 7/8 in front.
