Thread: are the t-rex 60 axles by rc4wd sronger than axials/venoms
Old 12-15-2011, 08:36 AM   #1
Default are the t-rex 60 axles by rc4wd sronger than axials/venoms
I found a set for cheap and was wandering about them strength wise
mudd_slinger is offline   Reply With Quote
Old 12-15-2011, 09:35 AM   #2
Default Re: are the t-rex 60 axles by rc4wd sronger than axials/venoms
if they are the CNC'd aluminum version I'd say yes, but if they are the plastic versions I would give a definite no, the plastic one will snap as fast as a stale sourdough pretzel. They look great for a scale rig and if they are driven extremely cautiously, they do ok but if you have an aggressive 'take no prisoners' style of driving, they will fail you very quickly.
BigSki is offline   Reply With Quote
Old 12-15-2011, 10:58 AM   #3
thats what i needed to know. Thanks
Old 12-15-2011, 10:02 PM   #4
www.ottsix.com
I have the plastic axles on my Trail Stomper...they haven't busted yet, but I fully expect it to happen at some point soon. They flex really bad, the clock is ticking.
crawl-o-matic is offline   Reply With Quote
Old 12-16-2011, 08:42 AM   #5
go with the axial axles , my t rex axles lasted about 5 runs before problem began . the axials are still running strong, as for the venom for me they were just a PITA.
these are just my opinions from my experiance with the axles
crawlhog is offline   Reply With Quote
Old 12-16-2011, 09:14 PM   #6
i agree... i had a set of t-rex 60's and a heavy throttle finger and within about 6 packs and a couple hard binds i snapped the front axle housing just beside the knuckle and spun the gears in the rear.. and my axial axles are still going stong after almost two yrs of sh*t and abuse with only one failure.... a broken rear axle from a bad bind shortly after i went lipo but other then that there still doing there job and imo excelling at it!!
EBKUSTOMS is offline   Reply With Quote
Old 12-17-2011, 12:41 PM   #7
thanks guys
are the t-rex 60 axles by rc4wd sronger than axials/venoms - Similar Threads
RC4WD T-Rex 60 Axles... STEEL_CITY_CRAWLER General Scale Talk 1 03-13-2009 04:20 PM
