06-18-2006, 02:08 PM | #1 |
Rock Stacker Join Date: Feb 2006 Location: westminster
| a little battery trouble
Here is my rig, I have done most things to it I have set out to do. The only things I have left are HG electronics and to four link it. The other day I put together a battery so I could get longer run times out of it. I used 6 Energizer 2500 Mh rechargables. They only lasted about 1 minute. I under stand the first time you charge them you dont get a full run time out of them, So I used some old ones that I have been using on my 3 W headlight for a few months. Same result. Should'nt you get a longer run time out of a 2500 Mh battery as compared to a 600 Mh battery? I had 2 of the standard batteries, so I linked them togetherso as not to double the voltage, but provide more current. That has been working good. My run rimes are around 30 minutes now, but the battery packs are heavy. Any ideas? Thanks |
06-18-2006, 02:44 PM | #2 |
I wanna be Dave Join Date: Sep 2004
are you shure you soldered them together correctly ? how many cells did you use ? if your gonne use a sub c pack use a hobby grade one.im not familur with the enegizer cells. |
06-18-2006, 03:26 PM | #3 | |
