01-12-2012, 02:03 AM | #1 |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
| WANTED: 4-Link geometry Guide?
Have a few very technical problems with tuning suspension designs. Does anyone have a link on how to tune out 4-link issues? I would like to learn more about suspension behavior. The current issue is; When climbing a wall, when it gets too steep. one of the front tires lift off and drop back, which is 'closer' to the rear wheels than when fully extended. |
01-12-2012, 02:36 AM | #2 |
Quarry Creeper Join Date: Jan 2011 Location: armstrong
| Re: WANTED: 4-Link geometry Guide?
sounds to me like you have a lot of torque twist try adjusting the spring on the back tire opposite the on that comes off the ground. another thing to do is flip the skid plate around 180 degrees so the motor is on the opposite side did that with my rig and it solved alot
01-12-2012, 10:10 AM | #3 |
Newbie Join Date: Dec 2011 Location: State of Denial
| Re: WANTED: 4-Link geometry Guide? http://mysite.verizon.net/triaged/fi...rLinkV3.1d.zip Even though this was made to work with 1:1 crawlers you should be able to make it work for an RC as well. |
01-12-2012, 12:26 PM | #4 |
Rock Stacker Join Date: Jan 2007 Location: On the rocks
what kind of crawler you runnin?
01-12-2012, 12:35 PM | #5 |
Try raising your REAR upper links a hole or two at the chassis and a little preload at the rear opposite side of whatever side is lifting up front. If you posted a picture we could really help |
01-12-2012, 01:14 PM | #6 |
Rock Crawler Join Date: Mar 2008 Location: ...in your meter box...
This is the thread that helped me figure it out...I still go back to it a couple times a year. Anti Squat and Suspension Tech Its a bit of a read but it will help explain WHY and HOW link geometry works. - |
01-12-2012, 01:49 PM | #7 | |
| Re: WANTED: 4-Link geometry Guide? Quote:
That is a very good read. | |
01-18-2012, 12:44 AM | #8 |
My rig is an MOA, so torque twist isn't really an issue. I've been researching the links you guys sent (Thanks btw) and I think I see a few places where I can adjust things better. Right now my upper links come down at a steep angle, and intersect with the lower links basically AT the mounting point. I'm going to try raising the rear-upper-link-mount on the chassis side.........alot! I haven't even begun to understand the front link setup yet, but I don't think it's an issue at this point. Left is front. |
WANTED: 4-Link geometry Guide? - Similar Threads | ||||
Link geometry ? | ScalerLover | General Scale Talk | 9 | 12-01-2010 07:54 PM |
Link geometry | Douginala | Newbie General | 2 | 03-28-2009 04:09 PM |
link geometry | solomon7 | General Crawlers | 11 | 01-10-2009 04:46 AM |
4 link geometry | Mikekx65 | Newbie General | 1 | 06-06-2007 04:30 PM |
link geometry, 1 to 1 scale | Trac95ker | Chit Chat | 2 | 01-28-2005 01:04 AM |
