06-18-2006, 10:33 PM | #1 |
Newbie Join Date: Jun 2006 Location: Redlands, CA
| Newbie here/With a shock question
Whats up everybody, ive been lurking around the forums fer a while, and found this site to be interesting. Im currently working on my build up of my 1:6 nylint its pretty modified (tummy tuck, inboarded shocks, extended wheelbase rear only, cut up tires ETC......its chopped and trimmed) I have a question, Im getting ready to install my savage shocks and am wondering when i do this will i be able to cut the limiting tabs, or will i still need to install some sort of limiting strap ???? Is this a good mod?? Oh and are there any members here from SOCAL area, if so i wanna know where you wheel, cuz i got a custom made rock garden(boulders and Concrete, hills, tree stumps...)in my backyard that im currently building up but im always looking for a newplace to play. thanksd Guys Russ P |
06-18-2006, 10:37 PM | #2 |
Rock Stacker Join Date: May 2006 Location: East Hartford, CT
After you install the savage shocks you will be able to cut the tabs and will not need to worry about the shocks pulling apart. There is a stopper inside the savage shock that prevents it from pulling apart.
06-20-2006, 02:18 AM | #3 |
cool thanks, they came in the mail today so im a break out the dremel tonite and start cutting away.
06-20-2006, 08:20 AM | #4 |
Rock Stacker Join Date: Jun 2006 Location: staring in your window
i used limit straps, the axles wanted to roll under the body on steep climbs and reversing. just a heads up.
06-20-2006, 08:38 AM | #5 |
RCC Addict Join Date: Dec 2005 Location: Beaver Falls
Any reason why you wanna cut the tabs? Are you speaking of the tabs on the side of the belly, below the blue arms? If so, there's no benifit in cutting those. Just slice and dice the pivot points for best flex. You can get up to 90 degrees of flex without cutting the side tabs. If you are speaking of the other tabs, forget this post |
06-22-2006, 10:09 PM | #6 | |
I also need to figure out how to shave the front axle, cuz it hangs on everything now that i have the tummy tuck finished. | |
06-23-2006, 05:39 AM | #7 |
Pebble Pounder Join Date: May 2006 Location: Southbury
I would suggest moving the front shocks closer to stock. Without a decent stance on at least one end of the truck, it's just gonna flop around.
06-23-2006, 10:02 PM | #8 | |
