01-16-2012, 10:30 AM | #1 |
RCC Addict Join Date: May 2011 Location: Utah County
| Ultimate Scale Yota REAR + K44 FRONT = under/overdrive?
I plan on ordering a cast yota front axle when they're released, but i have a cast rear coming in the mail. i thought that i could just use my spare front k44 with the rear yota until i get a front yota. then i realized the gear ratios might be different. i checked. they are the yota (rear) ratio is 2.53:1 the k44 (front) ratio is 3:1 does that mean the front pinion/driveshaft has to spin 3 times for the axleshafts/tires to spin 1 time? and the rear pinion has to spin 2.5 times for the tires to spin once? in terms of over/underdrive like in axial axles... that would be like putting underdrive gears in the front axle, wouldn't it? that's generally the opposite of what you would want, right? sorry for all the questions, i just need to bounce my ideas off someone. helps me think haha. |
01-16-2012, 03:17 PM | #2 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
| Re: Ultimate Scale Yota REAR + K44 FRONT = under/overdrive?
Yes it would be OD in the rear, not what you want. It will most likely increase torque twist and a few other nasty habits. Buy it will probably pull some mean wheelies with some decent power. |
01-16-2012, 04:37 PM | #3 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
But it'll look like a d44 and ford 9 in. So it will be pretty true to scale if in a ford lol
01-17-2012, 12:03 AM | #4 | |
| Re: Ultimate Scale Yota REAR + K44 FRONT = under/overdrive? Quote:
i think i'll try it out. it wont get much use until the yota front axle comes in, i just want to be able to drive it around the kitchen/couch/lovesack until it does come. | |
01-17-2012, 01:27 AM | #5 |
Pebble Pounder Join Date: Jan 2012 Location: a box
just put a little bit shorter tire on the back that will help |
01-17-2012, 10:26 AM | #6 | |
01-27-2012, 01:49 AM | #7 |
if anyone was wondering, i am using this setup afterall (until i get a yota front axle). it doesn't push while cornering too bad... only on very loose surfaces, like gravel/wet rocks. edit: but that's to be expected with any locked-differential vehicle |
Ultimate Scale Yota REAR + K44 FRONT = under/overdrive? - Similar Threads | ||||
How Strong Are Ultimate Scale Yota Axles? | alexchen86 | Axial SCX-10 | 8 | 10-15-2012 04:15 PM |
RC4WD K44 Ultimate Scale Axle's | Locked Up | General Scale Talk | 2 | 10-14-2010 10:41 AM |
