Thread: Stock Transmission Help
Old 01-19-2012, 12:34 AM   #1
Default Stock Transmission Help
Greetings RCC.
Several days ago I noticed my week-old RTR Honcho has a "jumpiness" to it, similar to a 1:1 rig slipping a clutch, mainly at 1/4 throttle (right in the crawling range.) I thought it was the motor I bought and soldered in, but after 4 days of hair-pulling and troubleshooting, I finally believe the culprit is my transmission.
Can anyone shed any light on why the stock Axial transmission would feel as though it was severely oscillating inside? I am weary of taking it all apart just yet.
A humble TIA.
EDIT: I just realized my browser did not reset my page. This thread was intended for the Axial SCX10 sub-forum. I apologize, perhaps the moderators can move my thread as I cannot delete it.
ModTrialsRider is offline   Reply With Quote
Old 01-19-2012, 07:26 AM   #2
Default Re: Stock Transmission Help
I would check to make sure each wheel is solid to the other wheel on the axle (checking for a bad diff or CVD), check in various spots during a full turn of a wheel.
Then check an axle to the motor, this checks the driveshaft and input gears in the trans.
Then check an axle to the other axle.
All should be done in different spots as you rotate a wheel or axle.
You may have stripped 1 or more teeth in a gear, thus the jumpiness.
Charlie-III is offline   Reply With Quote
Old 01-19-2012, 07:43 AM   #3
Looking for new Trails
yoda@4x4's Avatar
X2 on checking your axle diff's you might have spun the iron cross in the case...
as for the tranny there is nothing to it you might have taken some teeth of the idler gear and or have something hanging up the gears.
I would pull it out and you us one on these links and a clean work space and check it out and relube and go from there...
AX90014 / AX90016 - SCX10 w/Trail Honcho Body
AX90022 - SCX10 Honcho RTR
yoda@4x4 is offline   Reply With Quote
Old 01-19-2012, 11:02 AM   #4
You really should take the time to check out the tranny and maybe even upgrade it while you are in there. It is super simple and easy to take out and take apart. The experience will only benefit you down the road!
Tbone25 is offline   Reply With Quote
Old 01-19-2012, 07:47 PM   #5
Thanks for all the helpful replies everyone!!!
I just went ahead and tore the transmission out and re-built a few times till I found the lube setting I wanted. Seems to have fixed for now.
Thanks again for going easy on me! I'll learn soon enough...
Old 01-20-2012, 08:48 AM   #6
Glad it worked out, hope you can have some fun for now!
Stock Transmission Help - Similar Threads
900hp and Stock Transmission BJoe Chit Chat 95 01-16-2009 11:37 AM
Stock Transmission Carnage kajo Tamiya TLT Crawlers 12 08-01-2006 09:44 PM
How To- Maxx 2.5 Sliders on Stock or Losi/Associated Transmission USATorque55 Tamiya TLT Crawlers 1 10-09-2005 07:25 PM
