06-22-2006, 09:39 PM | #1 |
Rock Crawler Join Date: May 2005 Location: Minnesota
| winch installed!
FINALLY got my winch finished. after three different designs and cutting of sh!t that ended up not needing to be cut its in!!!!!! i just used a 1/4 servo. gutted it and just used the motor. mad a spool about 9 months ago that i attached. and just used some string. thinking im going to go raid my step dads tackle box for 10lb fishing line it doesnt have a ton of torque but enough to get me off for high centered. ill let the pics explain the rest..... all thats left is oring the axles and prolly get a little more wight on the front axle!!! |
06-22-2006, 10:21 PM | #2 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
Im going to put some lead in my front end!! LOL, when I barely push down on the front it helps climb a little/more traction, plus it doesnt flip backwards That sounds wrong but its trueeeeeee!! |
06-22-2006, 11:15 PM | #3 | |
testin out the winch about an hour ago and the line snapped under presure! time for the fishing line! | |
06-23-2006, 03:25 AM | #4 |
Rock Crawler Join Date: May 2006 Location: Burrillville, RI
nice job... thinking outside the box is cool... as for weight... I run 7oz of lead in each fron tire and it has helped a bunch... I didnt have bb's available so I used oval 1/4 oz fishing weights....it seems to work good... Keep us updated with your winch !!!! |
06-23-2006, 09:51 AM | #5 |
today i plan on installing the fishing line and mount the winch better. i pulls right off the velcro. i was hoping that would work so i could just remove it easily. i have some angle aluminum that i am going to mount it with. hopefully pics to follow after finished!
09-05-2006, 03:33 AM | #6 |
Newbie Join Date: Aug 2006 Location: Sydney Australia
i was just wonderin how did you wire the winch is it to a reciver or to a switch i have a winch but i need to wire it its a standard savage servo 6.5kg if im not mistaken |
09-05-2006, 04:56 AM | #7 |
RCC Addict Join Date: May 2006 Location: Aroostook county
for the weight thing, just stick a rock between ur stinger and hood, LOL |
