Thread: ax-10 axle
Old 01-06-2013, 09:58 AM   #1
Default ax-10 axle
I just found that one of the screw holes that hold chub on is striped. Is there an easy fix for this with out buy a new axle housing? I looked for a fix but couldnt find one. please help
thanks
buggynutt is offline   Reply With Quote
Old 01-06-2013, 10:23 AM   #2
Default Re: ax-10 axle
I build short steel beef tubes out of 1/8" pipe. Drilled & tapped for 3mm they keep everything locked down.
WHITE-TRASH is offline   Reply With Quote
Old 01-06-2013, 10:27 AM   #3
Do you have a pic of one you have made?
thanks
Old 01-06-2013, 11:50 AM   #4
Crap picture but you get the idea.
I wrap them in 2 layers of electrical tape so they are a snug fit in the housing. I also tap a hole in them to pin them in place from the front.
ax-10 axle - Similar Threads
RC Axle Master Axial AX10/SCX10 Rear Straight Axle Kits LetsHandleit Axles, Trannys, T-case 41 06-24-2012 06:57 PM
rear straight axle lock out's for tamiya tundra highlift axle tundrafan01 General Scale Talk 9 05-19-2011 01:30 AM
Lube TLT-1 stub axle to inner axle shaft or run it dry??? Natedog Tamiya TLT Crawlers 5 01-17-2006 02:53 AM
