07-11-2006, 08:53 PM | #1 |
Newbie Join Date: Jun 2006 Location: Durant
| traxxas 32-pitch trans
anyone using this trans in a crawler? I know that the pede trans is primarily used, but since I already have one handy...just wondering if its been done and/or is it a capable trans to use.
07-11-2006, 09:15 PM | #2 |
Quarry Creeper Join Date: Jun 2006 Location: BUILDING A CSC-1 in south mississippi
need pics!
07-11-2006, 10:27 PM | #3 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Traxxas Hawk / Sledgehammer trans?
07-12-2006, 05:14 PM | #4 |
| sledgehammer trans
yeah. that would be the one. I have an old sledgehammer laying around and I would like to put something off of it to use...
07-12-2006, 06:11 PM | #5 |
Pebble Pounder Join Date: Jul 2005 Location: Greece
The problem with the Sledge tranny is that the motor is mounted on top. The pede's mounts it lower. Other than that the tranny is well built. I have a sledg and have beat it without damaging a gear.
07-13-2006, 02:35 AM | #6 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
That ^ and aren't a lot of the gears exposed?
07-13-2006, 02:32 PM | #7 |
| gears that are shown
there is a cover just like that of the pede trans. so really, there are no gears shown. I do not run a cover...so there is the pinion and spur gear showing. the only setback that I can see is not having low enough gearing available, and the fact that the output shafts cannot be removed from the outside like on the pede. Plus if you break them...you can't just buy a cheap plastic output...you have to buy one that has a metal shaft incorperated into the output.
07-13-2006, 02:55 PM | #8 |
Rock Crawler Join Date: Mar 2004 Location: Where it's wet
I would check the gear ratio first, then compare it to say, a pede trans... Or you could try it and let us know how she goes ;)
07-14-2006, 03:50 AM | #9 | |
Rock Stacker Join Date: May 2005 Location: Streetsboro
07-14-2006, 02:11 PM | #10 |
| pinion
well, I ordered a 9 tooth pinion gear today...guess I will see what that does. The stock pinion is 11...I had trouble finding anything lower, plus if I go any lower it might mess with the meshing of the gears...but I don't know, this is only my 2nd. 32 pitch trans a have messed with. Yeah...for the price of ordering all the parts I wish I still had my pede trans. I found out that if you leave things laying around for too long at my house they seem to disapear...in the TRASH...:-( |
