09-03-2012, 02:38 PM | #1 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
| Shock Limiting Question
Hey guys, I have a problem I haven't run across before. I did some searching, but couldn't find what I was looking for. I'm rebuilding an SCX-10 (1.9 with Pro-Line scale shocks and Hand Bros CMS), and with my new steering setup I found that I needed to limit the front shocks just a bit (externally) to keep everything turning smoothly during articulation. My question is this: Do I need to also limit the rear shocks to keep all 4 corners somewhat equal, or does it matter? I know that a lot of builds have different length shocks front and back, but that doesn't necessarily mean the shaft stroke is different. If I don't limit the rears, will it allow the truck to flex in a "weird" manner, or do I want to leave them unlimited to take advantage of the extra articulation? Secondary question: Will the same apply when I build my AX10 sporty in a couple of months, or do the rules change for comp rigs? Thanks in advance for all the help! Last edited by papabash; 09-03-2012 at 02:40 PM. |
09-03-2012, 03:19 PM | #2 |
Rock Crawler Join Date: Dec 2011 Location: Las Vegas 89110
| Re: Shock Limiting Question
do you want to limit the travel or the entire shock length? and most of that id do internally not externally |
09-03-2012, 03:27 PM | #3 |
Here's my opinion...... On the SCX, do what you have to do / what you want to do. I run the CMS on my SCX, without limiters of any kind, and let the drag link and tie rod hit each other at max stuff. Haven't had any servo related issues. Yet anyway. On a comp rig, run the "correct" length shock. Don't limit if you can help it. A little fine tuning is OK, but I've seen comp rigs with 1/2" or more of external limiting on a 4" shock and it makes me cringe. This lets the tire lift more in relation to the chassis, thus keeping the CG lower. And shorter shocks are lighter, and mount lower, keeping the CG lower. I've done all kinds of shock shaft mixing and matching, and trimmed shock bodies (like the MRC pro shocks) to get to the perfect length. |
09-03-2012, 03:36 PM | #4 |
There's no hard rule that you need to limit all 4 corners. Limit your fronts to preserve your steering function and my vote would be to let the back end fly if it wants. I use Slash front shocks at all 4 corners on my SCX, and it doesn't seem to me that the fronts and rears articulate the same even though all shocks are the same length. On the AX, I personally favor leaving them all the same length, but still, there's nothing saying you have to. |
09-03-2012, 05:05 PM | #5 | ||
| Re: Shock Limiting Question Quote:
09-03-2012, 05:09 PM | #6 | |
That's what I was thinking, just wanted some verification. | |
Shock Limiting Question - Similar Threads | ||||
Swx/losi shock limiting? | jeepster73 | Axial AX-10 Scorpion | 2 | 01-15-2011 04:34 PM |
shock limiting. servo "blue arrow" | es79 | Newbie General | 2 | 04-02-2010 07:23 AM |
Limiting shock question | g_green | Axial AX-10 Scorpion | 5 | 02-16-2010 07:28 PM |
shock limiting | ped453 | Losi Mini-Rock Crawler | 4 | 09-03-2009 05:25 PM |
Shock limiting | crawladan | Losi Mini-Rock Crawler | 9 | 03-05-2009 05:05 PM |
