08-05-2006, 10:43 PM | #1 |
Quarry Creeper Join Date: Aug 2005 Location: On the yellow dummy dumper
| driveline issues
tired of havin the driveline pop off the yoke?? well you can easily fix that using my method. all you gotta do is take the metal yoke and press the pin that connects to the slider out. you then take a nail that fits through the hole and is fairly long and put that through the hole. bend the ends until they are like the picture below and you are set for trouble free driveline issues |
08-05-2006, 11:40 PM | #2 |
I'm going to start to sell these, this will be a hot item later this year. Unless folks have driveline angles that are correct...sucker, fix yer junk right Nice trick scoot'ster Better have spares on Sunday because WRC is really bad on parts. |
08-05-2006, 11:42 PM | #3 |
i did this because i cant fix my angles, i fixed em as much as i could, but i still broke stuff!! so far, knock on wood, the only time my crawler has broke in a comp was the time i was using borrowed electronics and i listened to someone about my gear mesh |
08-05-2006, 11:53 PM | #4 | |
Oh...yeah... right sucker. Just cut and rotate the axle housings near the knuckles. Come on, the 1:1 LC guys do it, why can't you? | |
08-06-2006, 12:10 AM | #5 |
I'm not convinced it's angles, my driveshaft ends up near correct and it pops off. It just started to happen, so I'd like to think it's a worn out plastic piece. |
08-06-2006, 12:14 AM | #6 | |
If Scoot'ster were to post a picture of his angles you'd agree about the crappy angles. We're all amazed that his junk actually works. Go get Jato shafts, you have a job, you have $11 in your pocket fool. http://www2.towerhobbies.com/cgi-bin...?&I=LXKMG2&P=7 | |
08-06-2006, 05:03 PM | #7 |
Pebble Pounder Join Date: Jul 2005 Location: Greece
I have a truck that was snapping the Pede drive lines like twigs. To solve the issue I replaced them with Maxx ones.
08-06-2006, 06:07 PM | #8 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
It would look nice and clean if you could find a small machine screw and nut to use instead of having to bend a nail around like that.
08-06-2006, 06:15 PM | #9 |
that was the problem, i couldnt find one small enough that was long enough. it doesnt look bad when its on the truck
08-06-2006, 08:21 PM | #10 |
Pebble Pounder Join Date: Aug 2006 Location: Suffolk
I can't see that lasting very long, it's going to bind once the u-joint bends and destroy the plastic yoke. If you don't want to buy a new yoke, which I don't understand when fixing it right will cost more, just use a piece of all thread rod and two lock nuts in place of your bent nail. |
08-06-2006, 09:18 PM | #11 |
Gold Star Baby Momma! Join Date: Feb 2004 Location: Maumelle, Ar
I think it is pimp yo, hell you need to gold plate that sum biotch, that will quiet down the haters Kevin |
08-06-2006, 09:50 PM | #12 | |
08-06-2006, 10:05 PM | #13 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
Have you tried grinding down that nub on those yokes? I'm betting part of your problem is it is stickng so far out you get some wobbling out of it which pops out the connecting pins. Then again, having said that, MGS511 spent a good 1/4th of the day today putting his back in. But his problem was the plastic is all warped. |
